Reamer & reaming chamber - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-25-2011, 04:10 PM Thread Starter
Date registered: Oct 2008
Vehicle: 1985 300D Turbo 123.133 & 82 300TD
Send a message via AIM to bpjenks Send a message via Yahoo to bpjenks
What do you know of:
Mercedes Heavy Duty Carbon Reamer for Pencil Glow Plug Chambers and quality glow plug replacements. I have heard that it is necessary when replacing the plugs.
I found these:
Bosch Glow Plug - Direct OE Replacement
1981-1987 Mercedes Benz 300TD
For $13 ea.
bpjenks is offline
post #2 of 5 (permalink) Old 07-25-2011, 05:31 PM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
Using a Glow plug Reamer or an alternative method to clean the Carbon out of the Glow Plug Holes increases the life of the Glow Plugs.
On the Engine stated in your Post Bosch or Beru Glow Plugs hold up the best. The Bosch Plugs cost less and are more available.
In the pic below you see on the left my heavy duty all Steel homemade Glow Plug reamer with a 6 Flute (groove) Reamer on the End; and a Factory made Glow plug Reamer on the Right like you can get on eBay or some of the internet part sellers.
Name:	z Glow Plug Reamer 4 pic.jpg
ID:	388282   Click image for larger version
Name:	Glow Plug Reamer 2b.jpg
300Dman is offline
post #3 of 5 (permalink) Old 07-25-2011, 11:52 PM
Stretch's Avatar
Date registered: Jul 2011
Vehicle: 1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
Quoted: 557 Post(s)
You also need the reamer to make sure the hole for the glow plug is correct if you remove and replace the pre-chamber.
Stretch is offline
post #4 of 5 (permalink) Old 07-26-2011, 06:34 AM Thread Starter
What do you mean? Is it necessary to remove the pre-chamber to ream? How would you do that with the head still on and put things back, correctly?
I am also concerned to know how you know when you have thoroughly reamed the carbon out of the hole well enough?
bpjenks is offline
post #5 of 5 (permalink) Old 07-26-2011, 10:47 AM
Vehicle: 1984 300D
Quoted: 73 Post(s)
It is not necessary to remove the Prechamber to Ream out the Glow Plug holes/bores.
Glow Plug reaming.
Below is close to what is written in the Factory Service manual.
Prior to installing Glow Plugs, clean Glow Plug Channels and Bores and Prechambers with a Reamer. For this purpose, fill the flutes (grooves) of the Reamer with Grease and Ream the Glow Plug Channels.
(The Grease traps the carbon particles; you may need to wipe off the Carbon/Grease and re-grease the Reamer if it fills up with too much Carbon.)
After Reaming the Glow Plug channels, crank the Engine Several Times with the Starter Motor, so that the residue is blow out of the Chamber. (Before you do this part tie down the Manual Shutoff so Fuel does not spray out of the Glow Plug Holes when you crank the Engine.)
According to the Mercedes Manual the above is considered good enough to clean out the Glow Plug Holes.
My onpinion concerning the use of a Brush. I do not know if it is a benefit or not. Certainly Mercedes does not mention using a Brush.
You would think that on the way in a Brush would push loose stuff inside of the Precombustion Chamber.
So use your best judgement concerning the use of a Brush.
300Dman is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Reaming Glow Plugs misterkennedy W123 E,CE,D,CD,TD,TE Class 54 10-11-2010 04:38 PM
Glow plug reaming with the tool BuckeyeTheDog W123 E,CE,D,CD,TD,TE Class 5 10-31-2009 12:12 PM
Glowplug reaming ChuangTzu W123 E,CE,D,CD,TD,TE Class 22 03-12-2009 12:12 PM
Glow plug reamer torkq W123 E,CE,D,CD,TD,TE Class 1 01-27-2008 01:28 PM
Should I get the reamer tool? MBeige W123 E,CE,D,CD,TD,TE Class 8 12-18-2005 07:13 PM
