Lower Radiator Hose Heater - Caution - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-25-2010, 08:01 AM Thread Starter
Date registered: Jun 2009
Quoted: 2 Post(s)
So I've been doing some research on block heaters. Advice on the forum seems to be that the heater in the freeze plug is by far the best way to go, but is also expensive.
I was originally going to go for a lower radiator hose heater - like the kind Diesel Giant sells. However, just got off the phone with the manufacturer - Kats - who informed me that they don't recommend a vertical installation. Their heater is supposed to sit horizontally, with the bulb pointed down. Problems when the unit is vertical- air can get into the unit, even after the system has been bled, and the thermostat in the device has lower accuracy (by 5-7C). Several people have complained about burnt out hose heaters - this is the cause. Note that this caution doesn't apply to other manufacturers - like the Zerostart hose heater.
Figured that would be useful to other folks thinking about heaters.
bcameron is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Radiator Lower Hose Abdullah2009 W126 S,SE,SEC,SEL,SD,SDL Class 1 05-27-2010 08:11 PM
Need help!! Expansion Tank Lower radiator hose busted! benzmiester W124 E,CE,D,TD Class 10 07-06-2008 12:15 PM
Lower Radiator Hose Diameter? pracklam W123 E,CE,D,CD,TD,TE Class 0 11-25-2007 12:56 PM
Lower radiator hose / clamp revision? gw17625410 W163 M-Class 2 07-05-2006 10:08 AM
lower radiator hose falconsprint W126 S,SE,SEC,SEL,SD,SDL Class 0 12-14-2005 04:13 PM
