3500 RPM @ 70 MPH...is this right? - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 09-21-2008, 10:14 AM Thread Starter
jtoma878's Avatar
Date registered: Mar 2003
Vehicle: '06 CLS500 '01 CLK320, '84 300D
Quoted: 2 Post(s)
Send a message via AIM to jtoma878
I can't tell if i'm shifting into 4th gear or not. Is this correct??
Joe T
'06 CLS 500 91K - Totalled
'01 CLK 320 210K! (rebulit motor @ 114K)
'84 300D Turbo 136K
'87 Jeep Comanche 4x4 139K - SOLD!
'94 Kawasaki ZX-6E 17K - GONE!
jtoma878 is offline
post #2 of 19 (permalink) Old 09-21-2008, 10:40 AM
cheapold280ce's Avatar
Date registered: Sep 2007
Vehicle: 1978 280ce euro found dead on Ebay
Using one of many calculators on internet you should be doing 74.4 mph at 3500 RPM if you have 195/70 14 in tires.
However the calculaors don't take into account torque converter losses e.g. they calculate direct connection or other losses such as friction etc.. You also didn't mention your tire size.
Overall it sound right ....
cheapold280ce is offline
post #3 of 19 (permalink) Old 09-21-2008, 11:03 AM Thread Starter
jtoma878's Avatar
Quoted: 2 Post(s)
that is the tire size, thanks!
Joe T
'84 300D Turbo 136K
jtoma878 is offline
post #4 of 19 (permalink) Old 09-21-2008, 01:22 PM
::matthew's Avatar
Date registered: Jul 2008
Vehicle: 1985 300D W123 Cali
in my '85, I do a little better...3K @70mph. 195 70 14, but RE gearing is a little taller
1985 300D cali 190K
::matthew is offline
post #5 of 19 (permalink) Old 09-21-2008, 01:24 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
im doing like 3200 at 60mph.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #6 of 19 (permalink) Old 09-21-2008, 02:11 PM
kinda related, when I searched for gear ratios to post an answer. I found where the gear ratios on a 280E I assume that means 280CE also were different between series.
3,58: 230E, 280E (2. / 3. Series)
3,54: 280E (1. Serie)
How do you tell the series apart? what differ's from first to second to third.??
post #7 of 19 (permalink) Old 09-21-2008, 03:01 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 213 Post(s)
On an '84 300D, the final drive is 3.07. Where did you get that calculator? Mine is around 70mph at 3500rpm.
MBeige is offline
post #8 of 19 (permalink) Old 09-21-2008, 03:35 PM
I googled something like gear ratio calculator I can't find it again and didn't tag it. heres another there are hundres out there.
Axle Ratio calculator
But like I mentioned before we don't have lockout torque converters and drag and friction are not taken into account.
post #9 of 19 (permalink) Old 09-21-2008, 03:37 PM
79Mercy's Avatar
Vehicle: 1979 280CE
I found it.
Tire Size Calculator
79Mercy is offline
post #10 of 19 (permalink) Old 09-21-2008, 03:46 PM
SO I guess benz torque and friction losses are 16.44%
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
3500 rpm on start up prML430 W201 190-Class 3 12-13-2007 08:29 AM
Flat spot at between 3000-3500 RPM Molotov W201 190-Class 3 09-25-2007 03:26 PM
Engine Shudder / shake above 3500 RPM ?? saraiks W163 M-Class 24 12-11-2006 02:05 PM
RPM at 80mph = 3500. Normal for '84 300SD? avakyan W126 S,SE,SEC,SEL,SD,SDL Class 8 08-04-2005 04:59 PM
miss / hesitation between 2500&3500 rpm??? kevin R170 SLK-Class 2 01-30-2001 09:01 AM
