Fuel sender removal - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-08-2004, 09:11 PM Thread Starter
jimmyl's Avatar
Date registered: May 2004
Vehicle: 1995 E300, 1985 300TD, 1981 300TD, 1980 240D
Fuel sender removal
This must have been gas tank clean up weekend, however I wasn't adventurous enough to remove my tank. I did remove the sending unit and the screen, and thought I would post a few pics in the hopes that one day someone might like to see what they are getting into before the actual work.
I have an '80 300TD, and the wagon tank is different than the sedan, but sedan owners will get the idea. As a poster stated, the sending unit isn't real tight, so don't worry about buying that 46mm socket (or whatever size it was). Channel locks worked fine. My screen was amazingly clean, and the sending unit was crudded and slimey, but not super nasty. The hardest part of this whole job is figuring what to do with the old diesel fuel. I may put it in the tractor if I can figure a way to filter it. (I drained it into a large bucket that had a little cotton wood and grass debris.
jimmyl is offline
post #2 of 7 (permalink) Old 02-15-2008, 03:06 PM
Date registered: Dec 2006
Vehicle: 1983 300d turbo (silver), 1983 300d turbo (green), 1984 190d 5 speed, 1984 volvo 245 (240 wagon)
sending unit
Hi. I have an 84 300td wagon and the fuel gauge just stopped working---My mechanic tells me that the sending unit is bad. Is replacing one a hard task? Any help from you would be appreciated. I am not that mechanically inclined.
Thanks in advance for your feedback.
rattan1 is offline
post #3 of 7 (permalink) Old 02-15-2008, 03:25 PM
chad300tdt's Avatar
Date registered: Jun 2007
Vehicle: 1985 300CD
The hardest part is loosening it. If you have a new one ready for replacing, it should only take about 10 minutes to swap it out. Cleaning and repairing the old one is a little more involved but possible.
Chad
1985 300CD - "Gladys" | 1998 Acura 3.0 CL | 1993 Acura Vigor GS | 2005 Dodge Magnum SXT AWD
"Pleasure in the job puts perfection in the work." - Aristotle (384-322 B.C.)
chad300tdt is offline
post #4 of 7 (permalink) Old 02-16-2008, 07:15 PM
thanks chad300tdt. i will first try to clean it.
rattan1 is offline
post #5 of 7 (permalink) Old 06-10-2008, 05:51 PM
20swrt's Avatar
Date registered: Sep 2006
Vehicle: 83 300CD, 07 ML320 CDI, 04 WRX, 86 300D (totalled by my neighbor), 85 300D (sold)
Quoted: 45 Post(s)
Is it possible to remove the sender on a 300CD without removing the tank ?
20swrt is offline
post #6 of 7 (permalink) Old 06-10-2008, 06:32 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Yes just remove the first aid kit and its directly under it. The sender in the wagon is in a different place then the sedan and coupes.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #7 of 7 (permalink) Old 06-11-2008, 06:14 AM
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
Quoted: 20 Post(s)
Mr. Funnel
Kind of a neat device.
Gregs300CD is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
