Starting 1965 220 SE WITHOUT AT Installed . - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-12-2019, 11:03 AM Thread Starter
Buzz-Shop's Avatar
Date registered: Aug 2017
Vehicle: 1965 220 SE AT Survivor Original "Black Death" . 1965 220 SE AT White . 1985 Gold 380 SE Daily Drive
Quoted: 25 Post(s)
Aluminum Torque converter cracked in two pieces . I have the tranny out of the car and don't have time to work on it . Curious if it's okay to start . Already pulled the tank and everything (and put back in) and just want to keep good fuel going through . I suppose I need to plug the radiator lines . Do not remember even if there are cooling lines . I can also drain the tank . Is that good enough . May sit a year or so . John
Name:	MERCEDES WHITE .jpg
Buzz-Shop is offline
post #2 of 3 (permalink) Old 07-12-2019, 03:02 PM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 65 220SEb, 97 SL500, 98 E320 Wagon, 2002 ML500 - former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 1052 Post(s)
Makes no difference if the transmission is attached or not, the engine doesn't care. Just keep stuff away from the flex plate, as it will be spinning at engine RPM.
Dan
Buzz-Shop likes this.
LWB250 is online now
post #3 of 3 (permalink) Old 07-14-2019, 03:43 PM Thread Starter
Buzz-Shop's Avatar
Quoted: 25 Post(s)
Thank You Dan !
