A safety net for battery - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-21-2019, 01:21 AM Thread Starter
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 107 Post(s)
Lads and lassies,
I donít know about you, but the exposed batteryís terminals in my 1979 R107 always freaked me out as Iím simply not used to them - in modern cars they tend to be sheltered behind firewall. Some batteries, like the Exide in my case, donít come with plastic caps which can be used to cover & protect terminal, and disconnecting the negative every time I want to do something under the bonnet was a PIAÖ But of course thereís an answer for everything online - I got those PVC insulator caps, Ä3 for the set incl. shipping from China, and now Iím little less worried Iíll blow the car upÖ accidentally! y:
ID:	2522746   Click image for larger version
ID:	2522748   Click image for larger version
ID:	2522750   Click image for larger version
miko1aj is offline
post #2 of 3 (permalink) Old 06-21-2019, 04:18 AM
Date registered: Aug 2009
Quoted: 133 Post(s)
Be diligent checking the battery for corrosion. Those caps can promote it because they will trap moisture beneath them. Use a good quality silicone grease to seal the terminals.
Mike D is offline
post #3 of 3 (permalink) Old 06-21-2019, 06:28 AM Thread Starter
miko1aj's Avatar
Quoted: 107 Post(s)
Thanks Mike, agreed - though my car is dry weather / waterless clean only!
In the meantime I found out that MB can supply caps for positive terminals that clip in the two holes on the battery, p/n 001 546 08 35.... Darn, why is hindsight always too late!
Name:	MB battery cap.jpg
miko1aj is offline
