vacuum line. - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 05-20-2019, 11:20 PM Thread Starter
Date registered: Jun 2018
Quoted: 2 Post(s)
vacuum line.
In the middle of a lot of work and want to know what one connection is. I know the vent line to the intake but there is a short hose connectiom from the head to the manifold. It's about 4" long and goes vertically down from the head to the manifold close to the engine 2.8 straight 6 early 70's kjetronic.
The stub connection on the head
( using a mirror to look ) has a 1mm hole in it.
What is it for??
andyslc is offline
post #2 of 21 (permalink) Old 05-21-2019, 05:30 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 821 Post(s)
It would probably help if you told us what car you have, and where in the world you are located. You can put this info in your user profile.
rumb is offline
post #3 of 21 (permalink) Old 05-21-2019, 06:15 AM Thread Starter
Quoted: 2 Post(s)
Thailand. 1975 280SLC.
andyslc is offline
post #4 of 21 (permalink) Old 05-21-2019, 06:22 AM Thread Starter
Quoted: 2 Post(s)
Removing all the injection system and changing to Webers ( not chinese ones 😆 )
Total strip down and rebuild.
I'll try to post some photos.
ID:	2514556   Click image for larger version
ID:	2514558   Click image for larger version
andyslc is offline
post #5 of 21 (permalink) Old 05-21-2019, 06:33 AM Thread Starter
Quoted: 2 Post(s)
All started with a hole in the firewall.
ID:	2514562   Click image for larger version
ID:	2514564   Click image for larger version
andyslc is offline
post #6 of 21 (permalink) Old 05-21-2019, 06:43 AM Thread Starter
Quoted: 2 Post(s)
I'll post tomorrow with photos of the vacuum line I'm enquiring about.
andyslc is offline
post #7 of 21 (permalink) Old 05-21-2019, 07:02 AM
Date registered: Aug 2009
Quoted: 126 Post(s)
Is this the line you are referring to? The one between the cam box and intake manifold?
That is a vapor control vent. It acts as a PCV device.
Mike D is offline
post #8 of 21 (permalink) Old 05-21-2019, 05:31 PM Thread Starter
Quoted: 2 Post(s)
Yes, that's it. Thank you.
Can you explain its exact function?
andyslc is offline
post #9 of 21 (permalink) Old 05-21-2019, 07:07 PM
Quoted: 126 Post(s)
It is connected to the intake. The upper portion of the steel tube (the end going into the cam box) has a small orifice and a mesh filter. Any vapor/fumes/blow-by is drawn into the intake and is burnt with the fuel mixture.
Yes, you need it. If you plug it, you will have oil all over that shiny engine.
Mike D is offline
post #10 of 21 (permalink) Old 05-21-2019, 07:21 PM Thread Starter
Quoted: 2 Post(s)
Thanks.
I am coverting to carbs. The complete kjetronic being removed entirely including HP pump etc.( don't like 80+ psi in a 44 year old car)
7psi pump and regulator/filter at 2 to 3 psi going on.
The manifold system almost completed but by the sounds of it I will need to connect that port into the manifold.
andyslc is offline
Relationship between intake manifold, PSE pump, and air vents todd_raleigh W210 E-Class 45 01-20-2019 10:37 AM
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
Auto Climate Control on 1981 500SLC MikeSpeer R/C107 SL/SLC Class 10 09-28-2015 07:14 PM
Driving without the Vacuum Converter? Matt62489 W123 E,CE,D,CD,TD,TE Class 5 05-17-2013 02:20 PM
???Clear vacuum line connected to nothing 79Mercy W123 E,CE,D,CD,TD,TE Class 15 06-03-2007 09:46 AM
