1970 280SE interior door cap removal/replacement - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-10-2019, 07:21 AM Thread Starter
Date registered: Nov 2016
Vehicle: 1970 280SE
Quoted: 4 Post(s)
Iím going to replace a cracked door cap and Iím not sure how to remove it. Do I need a special tool?
Dallas280SE is offline
post #2 of 10 (permalink) Old 04-10-2019, 09:34 AM
Walt'89300CE's Avatar
Date registered: Oct 2018
Vehicle: 1989 300CE & 1971 280SE; 73.5 911T
Quoted: 38 Post(s)
This is from the Haynes manual
It looks like there are about 6 plastic clips that secure the top cap to the metal frame through slots.
Just guessing, but it looks like they prise upwards.
When you have the new piece, see how it attaches- you may need to buy clips, too.
Walt'89300CE is offline
post #3 of 10 (permalink) Old 04-10-2019, 01:28 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 795 Post(s)
Go to Harbour Freight and buy the $6 plastic trim removal tools.
rumb is offline
post #4 of 10 (permalink) Old 04-10-2019, 03:12 PM Thread Starter
Vehicle: 1970 280SE
Quoted: 4 Post(s)
Thanks. I have the Haynes manual but it didn't seem very clear to me.
post #5 of 10 (permalink) Old 04-11-2019, 06:12 AM
Date registered: Jan 2008
Vehicle: 1999 E320
Quoted: 37 Post(s)
will just pop off with correct pressure at attachments, make sure you remove door lock cover . The metal clips unless rusted, typically can be reformed and used
Ron
11 Porsche Cayman
15 F350 Diesel
Sadly Mercedesless.....
1999 E320 (sold)
62 220b (sold)
84 300SD ( sold)
72 450SL(sold)
71 220 Parts
81 380 Sl - Parts
Bondjames is offline
post #6 of 10 (permalink) Old 04-11-2019, 06:14 AM
Quoted: 38 Post(s)
If you get under one of the ends with a plastic panel removal tool, it will probably just pop loose.
When I removed the dash wood surround by the windshield, I had to remove the 2 trim covers above the A-pillars- they both just popped off easily.
If you look at how the clips attach to your new trim piece, it should be obvious how it is removed & replaced.
post #7 of 10 (permalink) Old 04-11-2019, 07:25 AM
Scoot's Avatar
Date registered: Oct 2002
Vehicle: 1967 250 SL, 1965 300SE lang
Quoted: 197 Post(s)
I’m going to replace a cracked door cap and I’m not sure how to remove it. Do I need a special tool?
Do you have a new door cap? If so, you can look at the underside and see where the clips will be. The only danger in removing the door clap is cracking the fiber board, and if yours is already broken then you don't really have to worry about that much...
Currently: 1965 300SE Lang, 1972 Alfa GTV, 1959 Borgward Isabelle Coupť
Past: 1965 250 SL, 1963 220 Sb, 1971 250 C, 1985 300 TD, 1967 250 S, 1968 280 S,1981 300 D, 1982 280CE, 3 Facel Vegas, Borgward Isabella Coupe, Alfa 2600 Sprint, Volvo P1900 (yes), numerous less interesting Volvos, ...
Scoot is offline
post #8 of 10 (permalink) Old 04-11-2019, 10:57 AM Thread Starter
Vehicle: 1970 280SE
Quoted: 4 Post(s)
Got it. Sounds easy enough.
post #9 of 10 (permalink) Old 04-11-2019, 10:59 AM Thread Starter
Vehicle: 1970 280SE
Quoted: 4 Post(s)
I just bought a set of interior panel tools so I'm hoping it pops loose without much effort.
post #10 of 10 (permalink) Old 04-11-2019, 11:00 AM Thread Starter
Vehicle: 1970 280SE
Quoted: 4 Post(s)
Thanks for the input. I do have a replacement cap.
Hood insulation pad for a 1970 280SE w108 Dallas280SE Vintage Mercedes-Benz 10 04-08-2019 07:46 AM
1970 Mercedes 280se Willo1975 Vintage Mercedes-Benz 1 04-01-2017 08:03 PM
1972 300sel and 1970 280se for sale Adil802 Vintage Mercedes-Benz 10 08-13-2013 05:01 AM
1970 280se w108 m130 parting out babakb For Sale/Wanted/Trade/Giveaway 1 04-26-2012 01:36 AM
1970 280SE Merc 11SLI Vintage Mercedes-Benz 4 05-01-2010 08:32 AM
