Ford 9" rear-end fit 250s - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 10-20-2018, 08:28 AM Thread Starter
Jmann3k's Avatar
Date registered: Oct 2018
Vehicle: 1966 250s
Quoted: 2 Post(s)
Hello all! I am wanting to install a Ford 9" rear-end for my 1966 250s. Has anyone installed one? Wanting to put 20" rear tires and trying to figure out how long my axel needs to be. I understand that wheel tubs will have to be modified. Thanks!!
Grubeguy likes this.
Jmann3k is offline
post #2 of 14 (permalink) Old 10-20-2018, 01:46 PM
Immoderately Caffeinated
Donf's Avatar
Date registered: Jun 2010
Vehicle: AMG E500 Various old stuff
Quoted: 2870 Post(s)
Are you converting it into a tractor?
Donf is offline
post #3 of 14 (permalink) Old 10-20-2018, 02:29 PM
Buzz-Shop's Avatar
Date registered: Aug 2017
Vehicle: 1965 220 SE AT Survivor Original "Black Death" . 1965 220 SE AT White . 1985 Gold 380 SE Daily Drive
Quoted: 27 Post(s)
For a Tractor I would go Diesel to keep function correct
Buzz-Shop is offline
post #4 of 14 (permalink) Old 10-20-2018, 02:36 PM
Donf's Avatar
Fergies were petrol ..😀
Buzz-Shop likes this.
Donf is offline
post #5 of 14 (permalink) Old 10-20-2018, 02:40 PM Thread Starter
Jmann3k's Avatar
Vehicle: 1966 250s
Quoted: 2 Post(s)
Really no help at all....
Nutz 4 Benz and Grubeguy like this.
Jmann3k is offline
post #6 of 14 (permalink) Old 10-21-2018, 09:13 PM
redghost's Avatar
Date registered: Oct 2012
Vehicle: 1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
Quoted: 446 Post(s)
The question suggested the answers. Sort of like asking if you should take a dump on a dinner table before the salad course, or, after dessert.
rumb likes this.
redghost is offline
post #7 of 14 (permalink) Old 10-22-2018, 06:32 AM
Scoot's Avatar
Date registered: Oct 2002
Vehicle: 1967 250 SL, 1965 300SE lang
Quoted: 203 Post(s)
Well, it would appear that no one here has done what you want to do.
Currently: 1965 300SE Lang, 1972 Alfa GTV, 1959 Borgward Isabelle Coupé
Past: 1965 250 SL, 1963 220 Sb, 1971 250 C, 1985 300 TD, 1967 250 S, 1968 280 S,1981 300 D, 1982 280CE, 3 Facel Vegas, Borgward Isabella Coupe, Alfa 2600 Sprint, Volvo P1900 (yes), numerous less interesting Volvos, ...
Scoot is online now
post #8 of 14 (permalink) Old 10-23-2018, 03:55 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 137 Post(s)
Ummm no. The question did NOT suggest the answers. It more suggested a "no, I've never" (and that likely not needing to be explicitly stated) or "yes, and here's some advice <and then the advice>." It certainly didn't suggest someone make a low-brow comment about dumps at dinner. I scratch my head at why elitists on this forum continually make it a point to poo poo (pun intended) someone's out-of box ideas or questions.
Jmann3k, there's no easy bolt-in for the Ford 9". If it's a matter of whether the native rear end will take an upgrade in horse power, it will (I've transplanted a Ford 289 into a 250S, and to no adverse effects at the rear end). If you continue to have concerns, I'd suggest using a rear end out of a 280se/sel or 300sel with a 3.5, 4.5 or 6.3. They're a direct bolt-in. If it's a matter of wanting wider tires, you'll probably find it easier to use adapters that fit the bolt pattern (it's a common one).
If you DO want to use the Ford rear end, you'll need to either construct your own adapters, or do appropriate surgery to your car to make it work. There's an old adage amongst 'rodders - "anything will fit in anything. It's just a matter of how" (and a matter of $$, time, a respectable tool collection, etc).
If you go down this path, keep a record of what you did and how - someone else may be facing the same question, and you'd be blazing trails. And post pics - we non elitists love pics.
Scoot likes this.
Grubeguy is offline
post #9 of 14 (permalink) Old 10-23-2018, 04:17 PM
Scoot's Avatar
Quoted: 203 Post(s)
So I salvaged the rear end of a W109 4.5 in order to possibly use it in my W112 lang. I'm probably never going to do that. Will a W109 rear end bolt into a W108 ??? Or are the mounts for the air suspension going to goof everything up....?
Scoot is online now
post #10 of 14 (permalink) Old 10-23-2018, 05:44 PM
rumb's Avatar
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 848 Post(s)
I think the answer lies on hot rod forums, not MB ones.
https://duckduckgo.com/?q=how+to+mea...=v110-6&ia=web
plenty of links that show how to do.
rumb is offline
