Just driven a w638 CDI 112..... - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-13-2019, 11:19 AM Thread Starter
Date registered: May 2019
Hi all, I have just driven a CDI 112 03 plate, 80K miles and manual. And no, rust hasn't killed it yet.
Two things struck me - the gear change and the brakes.
Gear change was bloody stiff, a quick Google and this seems quite common. If it's new cables is it a DIY job ? Found some for about 50 quid each so don't seem too expensive.
Brakes felt bloody awful, hard pedal, very little feel, is this normal ?
The engine felt/sounded good, a lot quieter than my 56 plate Mondeo !
No smoke when I accelerated hard.
Seemed to drive quite well for an old bus so might be interested in it.
I think I'm right in saying they are chain driven and maintenance free ?
Anything else I should be looking for ?
SimonBUK is offline
post #2 of 4 (permalink) Old 05-25-2019, 02:20 AM
Date registered: Feb 2019
Vehicle: w638 Vito 110TD Marco Polo
Hi,
Leaking injectors- fixable fairly readily. Electrical gremlins, central locking, warning lights.
Rust around windshield pillars.
The gears are stiff usually I think but the brakes should feel car like.
They are quite nice to drive- I have the older 2.3td.
Cheers,
Yellblob is offline
post #3 of 4 (permalink) Old 06-06-2019, 11:54 AM
Date registered: Jul 2006
Vehicle: Vito 114 tourer 2015: Vito 108d 97: 108d 98: Traveliner 2003 ; Aixam; z1100; xbr500; z440 ++++
Quoted: 40 Post(s)
as above... the brakes are car like in feel and ought to stop you very quickly.... does it have ABS? not standard but would be fitted on top of the left (passenger in uk) side inner wing.... biggish item with 6 brake pipes into it.
don't worry on timing chain... it would power a tank
638 engines commonly do 200,000 miles
fettling the gear change... 1st fit a "reverse gear repair kit" its not for reverse, its what changes cable movement into the gearbox, 25ish from merc (I've got a spare for 25 in the post)... only then worry about cables etc.... 15minutejob
if injectors iffy try cleaning off around them (back to metal) and replacing the copper washer with a new merc one (too cheap from merc to risk a dodgy 3rd party one)
I've got/ had a 108d and 2 cdi's...... most parts interchangeable between models.
BTW will be getting rid of my alloys and better tyres at some point
malcolm
Name:	A0002600437 discontinued.jpg
File Type: pdf COMPOSITE gearshift and cable adjustment.pdf (973.1 KB, 16 views)
post #4 of 4 (permalink) Old 06-06-2019, 01:59 PM
Good to know about the easy gearbox fix. What type of alloys have you got Malcolm? I’ve been looking at ML alloys which seem a reasonable option.
Yellblob is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Vito 112 CDI Electric Windows samhar V-Class 4 03-28-2011 09:58 AM
Hello Vito 112 CDI samhar General Mercedes-Benz 1 03-22-2011 08:10 AM
112 cdi (2002) Diesel pump aston V-Class 2 05-28-2010 01:49 AM
Mercedes Vito 112 CDI energysolutions For Sale/Wanted/Trade/Giveaway 0 05-24-2009 08:39 AM
good news diesel fans.... Guest (MBNZ) W211 E-Class 6 05-19-2002 11:56 AM
