W638 110D TD 2.3 OM601 Turbo fail/exhaust manifold leak - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-16-2019, 10:09 AM Thread Starter
Date registered: Apr 2010
Vehicle: R170 SLK 200 Kompressor, W638 Vito 110 2.3 TD
Quoted: 5 Post(s)
Hello everybody,
It seems I am out of luck with this car, now the turbo has failed. I have a large oil leak on the back of the engine. I am not 100% sure that the turbo is the problem or something else but the noise and the oil from the back of the engine seems to indicate that the turbo/exhaust manifold are gone. Why the exhaust manifold too? Because I can hear a noise only under load/cold start like a gas leaking pipe. So I took a look under the car and saw a lot of oil coming from somewhere above the turbine/engine...
So please help. What shall I do? Sell the car cheap and look for another in a better shape or fix this one and hope nothing else major fails...
morpheusRO is offline
post #2 of 2 (permalink) Old 03-24-2019, 12:35 PM Thread Starter
Quoted: 5 Post(s)
OK. So I got some time this week-end and I checked the exhaust manifold and it was not leaking, it was merely loose. I tightened the bolts and now the sound is gone.
It was it seems an easy fix in the end.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
P170 Vacuum/Intake Manifold Leak Identified jettech C208/A208 CLK-Class 2 04-22-2009 06:53 AM
Diagnostic help needed long post fatbillybob W163 M-Class 10 12-04-2008 04:56 AM
Oil Leak Under Turbo dentate gyrus W123 E,CE,D,CD,TD,TE Class 1 09-18-2007 11:43 AM
Need info for exhaust manifold leak johnqt3 R170 SLK-Class 2 04-19-2007 10:44 PM
Vacuum leak step by step diagnostic dtabler W123 E,CE,D,CD,TD,TE Class 0 06-26-2006 06:45 PM
