OBD2 scanner for Vito 638 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-02-2019, 10:53 PM Thread Starter
Date registered: Sep 2018
Vehicle: 2001 Vito van w638 108 CDI
Hi all,
Can someone please recommend an OBD2 scanner that reads and erases fault codes on a 2002 Vito 638 2.2 CDI. My current scanner will only erase fault codes, so i have no idea what the actual fault is. Would the iCarsoft MB V1.0 work??
Thanks in advance!
blues65 is offline
post #2 of 7 (permalink) Old 02-14-2019, 12:58 AM
Date registered: Apr 2010
Vehicle: R170 SLK 200 Kompressor, W638 Vito 110 2.3 TD
Quoted: 5 Post(s)
I think you need MB Star for that job.
morpheusRO is offline
post #3 of 7 (permalink) Old 02-14-2019, 04:27 AM Thread Starter
Thanks for the reply morpheusRO
I ended up buying the iCarsoft MB V1.0 and it works great on the Vito, it reads a heap of functions like rail pressure, (which was my issue, faulty hp pump), oil, fuel, air intake temps, injector firing time in m/sec, injector voltage, scan and clear codes and also has an on-board library to look up what the actual fault code is, the list goes on. It`s an amazing piece of kit at a very reasonable price. I highly recommend it!
blues65 is offline
post #4 of 7 (permalink) Old 02-14-2019, 01:08 PM
Quoted: 5 Post(s)
Nice! Do you know if it works on old vitos as well? Like the 38 PIN ones?
And can you share the link with the iCarsoft MB ?
post #5 of 7 (permalink) Old 02-14-2019, 11:13 PM Thread Starter
Not sure if it will work on the older Vitos with the 38 pins, there may be an adapter available.
Here is a link for anyone interested..... https://www.icarsoft.com/Product/s-2...oft_MB_V1.html
blues65 is offline
post #6 of 7 (permalink) Old 07-12-2019, 12:24 AM
Date registered: Jul 2019
Vehicle: 2002 Vito W638 108 CDI
G'day, do you know if that scanner can reset the SRS light on the 2002 Vito?
Damian Jones is offline
post #7 of 7 (permalink) Old 07-18-2019, 07:05 PM
To answer my own question: yes it does.
I bought the same scanner off eBay. Make sure you get online and update the scanner firmware first, then it talks to the SRS module just fine.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
OBDII Scanner $70+ off! MarcDavidMiller For Sale/Wanted/Trade/Giveaway 2 06-18-2013 05:35 PM
OBD2 scanner Young Blood R129 SL-Class 2 09-17-2005 06:49 PM
