Vito 638 speedo bad - why? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-23-2018, 08:39 PM Thread Starter
Date registered: May 2013
The speedo on my 2003 Vito 112CDi (non-ABS model) stopped working - apparently a common fault as they get older - can anyone here tell me why these usually stop working?
Blondeb3 is offline
post #2 of 8 (permalink) Old 12-31-2018, 04:04 AM Thread Starter
How about just a little hint?
Blondeb3 is offline
post #3 of 8 (permalink) Old 01-02-2019, 02:06 AM
Date registered: Apr 2010
Vehicle: R170 SLK 200 Kompressor, W638 Vito 110 2.3 TD
Quoted: 5 Post(s)
Is it only the speedo or the whole dash?
morpheusRO is offline
post #4 of 8 (permalink) Old 01-02-2019, 02:26 AM Thread Starter
Just the speedo, the needle is just sitting on 160kmh all the time.
Blondeb3 is offline
post #5 of 8 (permalink) Old 01-02-2019, 03:06 AM
Quoted: 5 Post(s)
Could be that the speed sensor is defective since all else works?
Usually there is a gearbox sensor that tells the dash the speed, but I am not sure on your model how you can check that.
post #6 of 8 (permalink) Old 01-02-2019, 11:01 PM Thread Starter
Thanks I don't know how to check it either but I'll have a look and maybe pull it out for testing to see if it's a coil or a hall effect pulse sensor or whatever it might be ... presumably the odometer operates from some other source because that is still working fine.
Blondeb3 is offline
post #7 of 8 (permalink) Old 01-03-2019, 11:21 PM Thread Starter
Before looking for the sensor at the gearbox end I pulled the speedo apart and squirted some lube into the plastic gears & ratchet mechanism - upon reassembly I found I had a functioning speedo!
After re-setting the needle position I found the speedo is tracking smoothly on acceleration but sticky and jerking back on deceleration. I'll just have to see how it lasts I guess!
Blondeb3 is offline
post #8 of 8 (permalink) Old 01-04-2019, 12:53 AM
Quoted: 5 Post(s)
Good news!
Keep us posted!
Blondeb3 likes this.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
