Removal of SAM from fuse box - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-12-2014, 08:08 AM Thread Starter
adamuk's Avatar
Date registered: Apr 2006
Vehicle: Vito 111CDi 2004
Before I break it how do I take the SAM from the fusebox?
Cheers lads!
Adam.
adamuk is offline
post #2 of 4 (permalink) Old 05-13-2014, 07:31 AM
Scott52's Avatar
Date registered: Oct 2012
Vehicle: W204 C320CDI 2009 and W639 Vito 115CDI 2006
Quoted: 90 Post(s)
I replaced mine. There's a screw at one end that you remove and then with a small screwdriver you release the tags on the sides and it swings down. It's sort of hinged at one end.
It comes off easily once you get the hang of it.
Scott52 is offline
post #3 of 4 (permalink) Old 05-13-2014, 08:04 AM Thread Starter
adamuk's Avatar
Yes. I figured it out in the end. I am always cautious about such things. An ecu or other gubbins with connectors and clips is just asking to be broken inadvertently.
adamuk is offline
post #4 of 4 (permalink) Old 08-12-2019, 06:22 PM
Date registered: Aug 2019
Vehicle: 2003 Mercedes Benz CLK320
Hi,
I have 2003 Mercedes Benz CLK320. I had a German Auto Repair shop say that I had a bad ECU and Front SAM. I knocked on the starter and the car finally got the car to start. However, when I turned it off and tried to restart it all I got was clicks. The Auto Repair wanted 2800.00 after their diagnostic fees to repair my car. I do not have that kind of money and now I think it is just the starter. I took the ECU out that he said had got water in it and the SAM. The look fine no water damage that I noted. However, with the car clicking when trying to start it I was thinking that I could remove the ECU send it in for repair and buy a new SAM from PartsGeek so I removed the ECU. Now I want to reinstall it however, when I go to slide the connectors back in place with the levers they will not go it. Am I doing something wrong or is there a trick to sliding them back in. I really need help to get this car up and running ASAP. I have also decided to buy a new starter and go from there.
V/R,
MJ aka Chief Jenkins, USN
ChiefJenkins2013 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
