Transmission problem Vito 639 - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-02-2012, 09:10 AM Thread Starter
Date registered: May 2012
Exclamation Transmission problem Vito 639
I have some problem with transmission some times, the car put in all greas on ex. 40km/h. Also when I drive and stop with brake it feels that car is still pusching forward.
cmdata is offline
post #2 of 15 (permalink) Old 05-02-2012, 09:50 AM
zenman 63's Avatar
Vehicle: ML63 AMG & 2 350 SLK with AMG kit.
Quoted: 52 Post(s)
Is this an Auto?
zenman 63 is offline
post #3 of 15 (permalink) Old 05-02-2012, 11:38 PM Thread Starter
Exclamation
Originally Posted by zenman 63 View Post
Is this an Auto?
Yes it is automatic
cmdata is offline
post #4 of 15 (permalink) Old 05-03-2012, 12:38 AM
zenman 63's Avatar
Quoted: 52 Post(s)
Ok good, has it been serviced?
Should be done every 40k
I would get the oil checked and service it with new filter etc.
Google 722.6 gear box.
post #5 of 15 (permalink) Old 05-03-2012, 12:46 AM Thread Starter
Smile
It should be changed but I have bought this car as used and I have runnit for 30K. But I will change Oil and filter and replay to you if it helps.
Do you now amout of oil and type of oil?
The is now information in owners manual.
cmdata is offline
post #6 of 15 (permalink) Old 05-03-2012, 09:58 AM
zenman 63's Avatar
Quoted: 52 Post(s)
Is very specialised oil and MB filter, get the oil there as well.
Better still get them to do it.
post #7 of 15 (permalink) Old 05-03-2012, 10:06 PM Thread Starter
Smile
I Have changed filter and oil, it was very dark and very burnd.
It seams to help but I have to run it for a couple of day's to realy see if it help.
Thanks for you tip.
cmdata is offline
post #8 of 15 (permalink) Old 05-04-2012, 11:30 AM
zenman 63's Avatar
Quoted: 52 Post(s)
Did you pump it out the oil cooler hose to drain the torque converter?
post #9 of 15 (permalink) Old 05-05-2012, 02:12 PM Thread Starter
Smile
I removed oil plug on converter, and lose the hose of oil cooler and remove all oil. I have run car now for two day's and it seam that it help't to change oil.
cmdata is offline
post #10 of 15 (permalink) Old 05-17-2012, 10:03 AM Thread Starter
Hello, Now I have runned car for a week, in the begining it seams to help change oil, filter.
But now the problem gone forward to a bigger problem. from 0 - 2100 rpm. there are huge vibration in hole car. after 2100 rpm. it's disepers. If I start from 0km/h and push forward vibration is huge, and on 50km/h 4 grear in vibration is bigg. I manual lower gear to 2 or 3 gear and rpm. increas to above 2100 all is okay if I put higher grear the vibration comes back. but if I go on higher rpm. and put higher gear an not rpm. drops. to 2100rmp it's okay. and I can do this on all gears. if I drive in 12okm/h in 5 gear all is okay then rpm. is 2300 if I lower speed so rpm goes down to 2100rpm vibration is back.
cmdata is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Which transmission oil for Vito 108D looser V-Class 14 10-21-2014 05:49 PM
Vito 111cdi auto transmission. seanyc5 V-Class 1 03-23-2011 01:30 AM
Vito 108CDI Electrical problem and Instrument Cluster problem DJDUNKY V-Class 2 03-30-2010 01:05 AM
VITO Automatic transmission problem Dominic1968 General Mercedes-Benz 0 07-12-2006 11:00 PM
