Transmission problem Vito 639 - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 05-17-2012, 02:24 PM
zenman 63's Avatar
Vehicle: ML63 AMG & 2 350 SLK with AMG kit.
Quoted: 52 Post(s)
Sounds like a torque converter problem
zenman 63 is offline
post #12 of 15 (permalink) Old 05-17-2012, 02:55 PM Thread Starter
Date registered: May 2012
Any idee how to check ? Fix ?
I also feal that when this happens, it a sound from engine like if engine, not running properly on all cylinders.. I have dificult to explain sound I hope you maybe understand how it sounds.
cmdata is offline
post #13 of 15 (permalink) Old 05-17-2012, 03:53 PM
zenman 63's Avatar
Quoted: 52 Post(s)
Is it like drone drone drone, a constant thing, and you can feel in all over?
It will mean box out and new torque converter.
post #14 of 15 (permalink) Old 05-27-2012, 11:53 PM
Youve done the right thing by servicing it as i've had servicing fix the issue before, but there is a couple things that can caus this.
One thing about light commercial 5 speeds is that the converter is on early and on in every gear, so it gets a workout, on a passenger car it is only on in 4th and 5th.
there is a newer transmission control module that reduces this vibration which will be big bucks and also the old one probably already done the damage to the converter
have the converter rebuilt and see if you can score a newer part number ETC control module off a identical vehicle as they are interlocked to the vehicles equipment(or find someone who can revirginise the control unit to have it coded to yours).
Sparch is offline
post #15 of 15 (permalink) Old 06-14-2019, 03:05 AM
Date registered: Apr 2013
Vehicle: Vito 115 CDI LWB 2008 in black - Aston DB7 Vantage Volante in Black - Range Rover Sport in Black
Hi. I think i have the same issue. I get a sort shudder / drone sometimes when going up hill, like the engine is struggling, if I drop a gear its fine. How can I check if its the TC, would that show up on a diagnosis?
pwheeldon is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Which transmission oil for Vito 108D looser V-Class 14 10-21-2014 05:49 PM
Vito 111cdi auto transmission. seanyc5 V-Class 1 03-23-2011 01:30 AM
Vito 108CDI Electrical problem and Instrument Cluster problem DJDUNKY V-Class 2 03-30-2010 01:05 AM
VITO Automatic transmission problem Dominic1968 General Mercedes-Benz 0 07-12-2006 11:00 PM
