Vito 638 heater - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-31-2012, 05:46 AM Thread Starter
Date registered: Feb 2012
Vito 638 heater
Whilst driving the other day I turned the heater down to cold, but after a while when the thing should have been kicking out cooler air it was still very warm!!!
I am away now working at the mo, so can not get to look. I was wondering if anyone else has had this trouble? any ideas on what it will be? will I need to get under the bonnet to sort this out??
Any help would be great ..............................please
Ballbagracer is offline
post #2 of 10 (permalink) Old 03-31-2012, 04:59 PM
Date registered: Jul 2007
Vehicle: 2016 Vito 116 Bluetec
Quoted: 6 Post(s)
I too suffered from this problem.... and intermittent hot air during cold usage.
Only thing was, that about 6 months later, my heater core sprung a leak Wasn't too bad, as the Aussie summer wasn't too far away. Looked into replacing it, that's the easy part. Its what is required to swap it that is the HARD part....
mr_v8 is offline
post #3 of 10 (permalink) Old 04-01-2012, 11:54 AM Thread Starter
Oh dear!! I will have to have a closer look when I get back home
post #4 of 10 (permalink) Old 04-24-2012, 04:34 AM Thread Starter
Anybody have any other ideas where I should be looking??
post #5 of 10 (permalink) Old 04-24-2012, 04:49 AM
Date registered: Sep 2011
Vehicle: 110cdi Traveliner
Control Cable?
There's a blue cable that runs from the heater controls to the valve that is above the clutch pedal, you will need to remove center dash panel and the heater controls and lie on the floor to see the bit that connects to the valve. Sometimes the cable bends at the end or becomes disconnected.
Might be an air lock?
Might also be the valve broken, they are not very strong.
Gandhi is offline
post #6 of 10 (permalink) Old 04-24-2012, 05:58 AM
gixxerpat's Avatar
Date registered: Sep 2005
Vehicle: Vito 280 ,ZX7r,gsxr 750, ,Z650 Cafe ,Benelli Tornado.Ford consul , Ford Pop , ,Chevy Astro,Dog,Wife
Quoted: 18 Post(s)
I noticed this problem AFTER i took my pollen filter out.....check the cables too..might have slipped a bit, i've noticed that the controls are getting harder to operate...another job on the list..
...Dont be a sheep.............
gixxerpat is offline
post #7 of 10 (permalink) Old 04-25-2012, 01:39 AM
Date registered: Oct 2010
Vehicle: 2000 Vito 113 , 2002 v230
heater tap
Behind the air filter is the heater tap, just make sure its closing fully, just a thought
on.electric is offline
post #8 of 10 (permalink) Old 04-25-2012, 12:31 PM Thread Starter
Thank you gentlemen. Vans away at mo having subframe bushes replaced, so will have a look in the next couple of days.
post #9 of 10 (permalink) Old 05-31-2012, 01:12 PM Thread Starter
I looked behind the air filter, but could not see a tap??
post #10 of 10 (permalink) Old 05-31-2012, 01:15 PM Thread Starter
Originally Posted by Gandhi View Post
Control Cable?
I do not see a blue cable? the only cables are black n yellow for the direction of the air. The heater control seems to be on a circuit board??
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
06 vito 639 heater issue Motherofgod V-Class 0 02-25-2012 02:05 PM
Vito heater not very hot paul9019 V-Class 12 12-12-2010 11:16 AM
Vito heater problem woodnstuff General Mercedes-Benz 1 08-09-2009 09:45 AM
VITO 108 D HEATER MOTOR stormrider V-Class 1 08-11-2008 11:00 AM
vito heater shaunsparkes V-Class 3 08-13-2006 12:37 AM
