Help needed please,head trouble - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-24-2012, 12:26 PM Thread Starter
Date registered: Jan 2012
hi, i have a 05 111cdi vito that constantly dumps it coolant out the expansion tank ive done the stat and the waterpump but still no joy, it still just gets a system full of air and chucks the coolant out aagghh!! i think the only thing it can be is the head or gasket i was just wondering if anyone had any pdf's of tdc and the timing marks etc
any help would be great
regards john
johno24 is offline
post #2 of 4 (permalink) Old 01-24-2012, 04:46 PM
Date registered: Jul 2006
Vehicle: Vito 114 tourer 2015: Vito 108d 97: 108d 98: Traveliner 2003 ; Aixam; z1100; xbr500; z440 ++++
Quoted: 40 Post(s)
as I've said before to many people...........
put your vin on here and I'll post the pdfs
the vin is at the bottom of the B pillar (behind the drivers seat) on the drivers side...... normally 3letters and 14 numbers (it varies)
I'm half way through my upgrade so It shouldn't take long
malcolm
post #3 of 4 (permalink) Old 01-25-2012, 08:33 AM Thread Starter
vin
hi malcolm the vin is wdf63960323105437
many thanks john
johno24 is offline
post #4 of 4 (permalink) Old 01-30-2012, 01:04 PM
Quoted: 40 Post(s)
Exclamation
639 cylinder head removal and repair pdfs.
unfortunately, like many mb instruction documents, it is a lot of information........
the info is specific to your vito, a 2005 111cdi, but it will include bits that do not actually apply to you e.g particulate filters........ this is simply the way mb presents its information.
the pages are in mbs order...... or "no logical order whatsoever" as we tend to call them.
you can print and then sort them (the easiest method) or use a pdf merge program to create a single large composite (I have to split them up due to the restraints on benzworld) using a pdf merge program from someone like cnet downloads.com
hope you get on well........ many people find that, with care, some operations can be omitted..... but I will not recommend it.
malcolm
File Type: pdf COMPOSITE 1 - 639-646 engine cylinder head removal.pdf (1.51 MB, 227 views)
File Type: pdf COMPOSITE 2 - 639-646 engine cylinder head removal.pdf (1.50 MB, 564 views)
File Type: pdf COMPOSITE 3 - 639-646 engine cylinder head removal.pdf (1.25 MB, 559 views)
File Type: pdf COMPOSITE 4 - 639-646 engine cylinder head removal.pdf (1.33 MB, 513 views)
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
CLK320 air condining not cold, trouble shooting help needed ASAP! dennisspeaks C208/A208 CLK-Class 0 08-06-2010 10:03 PM
Cyl Head Needed tahart Vintage Mercedes-Benz 1 06-09-2009 07:00 PM
Cyl Head Needed tahart For Sale/Wanted/Trade/Giveaway 0 06-09-2009 07:34 AM
560 Blown head gasket - how much trouble am I in? jjl W126 S,SE,SEC,SEL,SD,SDL Class 24 04-17-2007 10:14 PM
108cdi turbo trouble- replace INFO NEEDED mercedesnoclue General Mercedes-Benz 0 12-03-2006 08:10 AM
