poly v belt -- serpentine belt - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-16-2012, 06:13 AM Thread Starter
Date registered: Jul 2006
Vehicle: Vito 114 tourer 2015: Vito 108d 97: 108d 98: Traveliner 2003 ; Aixam; z1100; xbr500; z440 ++++
Quoted: 40 Post(s)
Exclamation poly v belt -- serpentine belt
I've had quite a few direct emails recently regards the poly v drivebelt (on left hand end of engine [viewed from front])
please contact on forum so others can get benefit.
I attach PDFs for 638 639 vclass etc poly v belts including fitting and adjustment........... note you need to know which engine and equipment fitted, although its easy to work it out by looking at the diagrams.
all will print on a standard printer and worth keeping for reference
File Type: pdf COMPOSITE 639 Remove install poly-V belt.pdf (759.5 KB, 455 views)
post #2 of 4 (permalink) Old 07-27-2014, 03:36 AM
Date registered: Jul 2014
Vehicle: 1998 V Class
Hi there thanks for the info. I have the 638 V230 petrol and just had Merc change my damper but now when I accelerate I get a quick noise that makes me feel its the belt slipping - Merc didn't change the belt.
SO Im thinking of changing the belt. However even with this info you posted I just can't understand it
sorry
Do I need a special tool to to loosen\tighten the tension?
In simple terms what exactly do I have to do to loosen\tighten? I can see stud 4 but what do I do - turn until the belt is loosened??
Just need advice thanks
bouncypelvis is offline
post #3 of 4 (permalink) Old 07-27-2014, 01:18 PM
jonny rash's Avatar
Date registered: May 2009
Vehicle: 2000 Vito 110CDI (never should have sold it), Current project 1999 V220 Ambient
If you feel/look on the outside of the tensioner you will see a square hole (?) in the middle.
A 1/2" driver (ratchet, knucklebar etc.) will fit in there perfectly allowing you to rotate the idler until the belt goes slack.
scratch that,I can't remember now and perhaps an E10 torx bit is required (the female socket type) it's much less likely that you will have one of those.
From personal experience the springs are pretty powerful and with the limited space there you need to be careful not to slip and pinch your fingers.
jonny rash is offline
post #4 of 4 (permalink) Old 07-27-2014, 01:25 PM
Hi johny
Yeah had a feel around and yes need a e10 torx - only £4 from halfords so will get one tomorrow
Also there is a small hole that you can pop a rivet/nail into once you loosen by cranking left which will keep it slackened to get the belt off/on without having to hold the wrench
Well it sounds easy saying it but I'll soon find out in practice if that holds true lol
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
S500 Poly (Serpentine) Belt Change dmac_S500 W140 S-Class 19 04-07-2015 03:43 AM
Poly V-BELT jacques Guého BenzWorld Help 3 10-27-2011 07:29 PM
V belt or Serpentine Belt replacement question bavenda W163 M-Class 2 01-29-2011 07:44 AM
"V Belt" as MB calls it or Serpentine Belt 98MBE320 W210 E-Class 12 01-05-2010 02:36 PM
poly belt / timing belt tsecolin General Mercedes-Benz 0 01-31-2005 10:32 PM
