Gearbox Problems on W639 Viano - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-24-2011, 04:53 AM Thread Starter
Date registered: Sep 2007
Vehicle: V280, Viano 3.5
Question Gearbox Problems on W639 Viano
A problem has occurred on my Viano 3.5 Automatic.
On startup the gearbox will not go into drive, if I override this (pressing the white button under the gear selector trim) then the vehicle drives but stays in 2nd or Reverse. Plus when selecting drive, the transition from neutral is very harsh.
The brake lights are working (you normally have to press the brakes to get it into drive) and I have checked the fuses in the main fusebox.
The display on the instrument panel PRND normally has one of the letters highlighted depending on the position of the selector, none of these is highlighted.
The lights on the trim by the selector are not lighting up either.
Does anybody have any ideas what to check next, there are a couple of small PCBs down by the selector, which one to look at first?
Russ Wood
RUSSWOOD is offline
post #2 of 8 (permalink) Old 04-24-2011, 05:11 AM
walsi's Avatar
Date registered: Mar 2007
Vehicle: 2000 108CDI, 2007 120 CDI long, Suzuki K5 GSXR track bike, 2005 Kawasaki ZX10R
Hi ya, get the codes read because it will save a lot of guess work, it could be an oil leak onto the electircs, it could be low oil(when was it last changed) it could be any number of things to do with the electonics on the box. Sorry i'm not much help
Cheers Martin
walsi is offline
post #3 of 8 (permalink) Old 04-24-2011, 05:29 AM Thread Starter
Reading Codes
I've got a mobile mechanic with a diagnostic reader coming round on Tuesday.
Hope he can see things in detail enough.
Russ
RUSSWOOD is offline
post #4 of 8 (permalink) Old 04-28-2011, 07:03 AM Thread Starter
Smile Resolution of Gearbox problems
The mobile mechanic came round and plugged in his STAR diagnostic kit, it reported that the gearbox selector sensor was not communicating.
Given the symptoms etc. he thought the diagnosis was sensible so I ordered a new one £140 plus vat.
He fitted it this morning and all started to work correctly.
There are three PCBs involved, one is up by the gear handle and contains the LEDs that light the PRND+- signals on the console.
This is linked by a ribbon cable (bonded on) to the main board. This board has a processor on it and also two hall effect transducers to sense the + and - of the tiptronic. This board has the connector into the main loom carrying the CANBUS wires, power, ignition power etc. It has a separate connector for the interlock solenoid.
The third board has a number of hall effect transducers that sense the PRND position of the lever.
The last two boards are mounted on a plastic sub-chassis about 2" by 3" by 2".
The gear lever itself has two magnets mounted on it, one for each of the sets of transducers above.
Russ
RUSSWOOD is offline
post #5 of 8 (permalink) Old 04-28-2011, 07:17 AM
zenman 63's Avatar
Vehicle: ML63 AMG & 2 350 SLK with AMG kit.
Quoted: 52 Post(s)
Good out come.
zenman 63 is offline
post #6 of 8 (permalink) Old 04-28-2011, 10:53 AM
walsi's Avatar
Bring back the good old days of a cable with an adjuster, even if that broke you could still crawl underneath and get it in drive.
walsi is offline
post #7 of 8 (permalink) Old 06-09-2019, 10:03 AM
Date registered: Jun 2019
Hi Russwood,
I know the thread has been 8 years but i have just encountered the same problem. My Viano 2008 stays at R position and if i manage to start the viano, it stays on 1st or 2nd gear.
Can you share with me the sensor type that you bought and how to install it.
My email is [email protected]
Thanks.
smarp is offline
post #8 of 8 (permalink) Old 06-14-2019, 01:27 AM
Date registered: Apr 2013
Vehicle: Vito 115 CDI LWB 2008 in black - Aston DB7 Vantage Volante in Black - Range Rover Sport in Black
Hi,
I am also having an issue with my auto box. I have a 2008 115CDI Vito Traveliner. Last weekend as I was driving it dropped down to a low gear then would change up. I stopped turned the engine off and when I restarted it and tried to put it in drive it wouldnt let me, so I restarted it and it was fine for about 500 yards then did the same. I was nearly at teh my destination so just carried on the 200 yds . On the way home it did a similar thing.
I have checked the oil and this appears to be OK, although I am not convinced I am doing it right as the dipstick i bought is getting oil on it all the way to the top of the measurement.
I have just driven it today and it was fine for about 6 miles then did it again, i.e wouldnt change up gear. I stopped put it in park gave it a minute then set off and it was fine again.
I am loathe to pay the £40 for diagnostic as I paid this about a month ago for another issue and it came back with nothing.
Any suggestions please?
pwheeldon is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
2004 viano w639 wayne216 Audio & Telematics Forum 0 08-19-2010 04:20 PM
W639 Viano Wing Mirrors carpetman V-Class 1 07-12-2010 10:35 AM
2004 Viano W639 3.0 L petrol / automatic drive train judder - opinions please edhsu V-Class 0 12-13-2008 09:40 AM
viano w639 3.0cdi bulb upgrade HELP dazzp99 V-Class 2 01-05-2008 01:45 AM
WTB Rear Seats - Vito/Viano W639 model (from mid 04) Australia fj20det V-Class 2 01-01-2008 03:55 AM
