Vito LWB 2004 639, had Re-con Gearbox but still hard to engage 2nd and reverse,Fixes? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-21-2011, 11:30 AM Thread Starter
Date registered: Mar 2011
Vehicle: vito
Hi all,
I have just fitted a re-conditioned gearbox, new DMF, new Clutch to my 115 CDI vito 2004, all the noises have gone and it drives well but it’s now hard to engage second and reverse gear, can any adjustment be made on the cables? Or do you know of any fixes?
I know the gearbox is good as its had all new parts, so it must be the cables or gear stick selector part, if I remove the gear gator I can see that the ball part of the gear stick (white nylon bush part) looks very worn out and the gear stick slops around a bit!
I have been quoted;
£55 +vat each for the cables
£227 + vat for the gear selector part (gear stick in the dash)
So want to try a fix or a way of testing to see what part is worn out or stretched.
Thanks,
mataos is offline
post #2 of 12 (permalink) Old 03-24-2011, 06:30 AM Thread Starter
Vehicle: vito
Any ideas? do the cables stretch on these, so they would need changing?
Thanks
mataos is offline
post #3 of 12 (permalink) Old 03-24-2011, 02:20 PM
walsi's Avatar
Date registered: Mar 2007
Vehicle: 2000 108CDI, 2007 120 CDI long, Suzuki K5 GSXR track bike, 2005 Kawasaki ZX10R
Hi ya, yeah the cables can stretch but also the linkage at the gearbox can get worn and cause problems aswell. The cables are adjustable.
Cheers Martin
walsi is offline
post #4 of 12 (permalink) Old 03-25-2011, 05:37 AM Thread Starter
Vehicle: vito
Thanks Martin,
Do you have any tips for adjusting, or just lenghten the outers and give it a try?
I cant see a way of adjusting at the gearbox end, so i guess there is adjustment in the cab under the gear stick?
It goes in to gear fine with the cables not connected so I think the gearbox linkage is good,
Mat
mataos is offline
post #5 of 12 (permalink) Old 03-25-2011, 07:31 AM
walsi's Avatar
Hi ya, it does sound like stretched cables if there is no free play in the linkage. I have never adjusted a 639 yet myself but the 638 was adjusted at the gear lever end.
Cheers Martin
walsi is offline
post #6 of 12 (permalink) Old 04-02-2011, 12:42 AM Thread Starter
Vehicle: vito
All fixed now, The gear stick part was so worn it had dropped and just slopped about, was full of dirt and grit which would of accelerated the wear, fitted a second hand stick and selector with cables and its perfect now,
There is also some adjustment on the cables if needed.
Mat
mataos is offline
post #7 of 12 (permalink) Old 04-05-2011, 02:43 PM
Date registered: Jun 2009
Vehicle: Dualiner 115 CDI
Hi Mat, was it an easy'ish fix? I've got issues with 2nd, 5th & 6th. Doesn't feel like gear box and sometimes the change is clean, others it just feels like i'm going to snap the gear stick!Is there any adjustment at the gear stick end? Any info would be greatly received....
Darren.
darrens2 is offline
post #8 of 12 (permalink) Old 04-05-2011, 03:02 PM
walsi's Avatar
Hi Darren, there is adjustment at the gear lever end of the cables, check the top of the gearbox that all the mechanism is moving freely first because that can get all jammed up and cause all sorts of problems. I wouldn't say it is easy to adjust the cables but it can be done, it might just be muck around the ball at the bottom of the lever. Good luck
Cheers Martin
walsi is offline
post #9 of 12 (permalink) Old 04-06-2011, 04:49 AM Thread Starter
Vehicle: vito
Hi Darren, You can check by removing the gear gator and try and put it in 2nd or reverse if it wont go try lifting the cable on the right to give it a bit more pull (lifting up the gear stick slightly) if this helps and your gear stick is worn out then its an easy fix, just replace the gear stick complete, or try adjusting the cables, trial and error!
Mine was so worn that the ball / gearstick had dropped enough so it was not giving correct pull on the cables, yours could be the same, The gear stick ball should have very little play and you should not beable to lift it up and down and wobble it about,
Or to check the gearbox end you can get under the van and remove the cables, then try selecting all gears by moving the selectors by hand.
Hope that helps!
mataos is offline
post #10 of 12 (permalink) Old 04-06-2011, 10:09 AM
Cheers Guys,
Mataos, the ball could be worn. There is about 2-3mm of vertical movement in the gear stick and that could account for the inconsistant gear changing. Sometimes it just drops in no problem, others it is a battle to get it in! I will have a good look when I get the chance and report back.
Darren.
darrens2 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
639 vito and v class genuine crated gearbox sparkyshep For Sale/Wanted/Trade/Giveaway 1 11-14-2014 03:54 AM
2004 639 Vito 115 CDI - Auto Transmission bladelocks V-Class 0 11-06-2009 04:50 AM
Vito 639 2004 on doors forsale zenman 63 V-Class 0 10-28-2008 10:44 AM
2nd gear won't engage on 6MT masterdog R170 SLK-Class 1 06-07-2008 02:56 PM
Reverse slow to engage ark91se W126 S,SE,SEC,SEL,SD,SDL Class 8 02-22-2008 10:11 AM
