Vito reving it's n**s off! help - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-10-2008, 08:03 AM Thread Starter
Date registered: Dec 2007
Hi all
When I push down the accelarater,and release, sometimes it keeps going up in the Rev's until I have to switch off and start again.
Anyone with advice (apart from the Merc dealers- CC maxed out!)
jobo is offline
post #2 of 4 (permalink) Old 04-10-2008, 08:29 AM
mattp94's Avatar
Date registered: Jan 2005
Vehicle: Vito 110CDi
I have no idea if this is relevant but I used to have a VW with a dodgy throttle return spring. If I accelerated gently it was fine, foot to the floor and it would just jam open. Could be quite interesting at times.
mattp94 is offline
post #3 of 4 (permalink) Old 04-10-2008, 12:26 PM
AntzV280's Avatar
Date registered: Mar 2008
Vehicle: V 280 Ambiente
I had a similar problem with my old VW Transporter. Turned out to be an age thing and just needed a lil bit of lubrication around the moving parts
Never underestimate the force that is....... WD40! You just never know it could be all it needs (hopefully)
Spring has sprung so off to the spring shop it is!
AntzV280 is offline
post #4 of 4 (permalink) Old 04-14-2008, 07:10 AM
Date registered: Aug 2007
The throttle in these are like fly by wire.
When you accelerate the cable actuates a magic box which sits up under the windscreen behind the heaterbox air intake ductwork, passengers side, engine compartment... (On a RH drive, don't know where it is on LHD). On my van 108CDi, the after market A/C pipework as fitted by the MERCDAD pushed the bowden cable to the point that it was around 30 degrees off straight...
Rerouted the cable to the other side of the pipework & now it is straight & as smooth as, accelerator pedal that is. Maybe your cable is frayed, you'll be able to see what happens when you find the end of it.
There should be 2 springs on the mechanism. 1 strung between a fixed point & the arm. The 2nd one is around the centre shaft of the actuator. (This is the thing that also stops your engine going back to idle immediately you take your foot off the gas. Those who have a dead speedo will notice this no longer works & you have to change the way you use the clutch. I digress.)
If yours has the cable run properly then check other mechanicals in that area & unplug the unit & replug it, sometimes swiping the terminals is enough to cleanup a dodgy connection. Sometimes. After the basics it gets expensive.
Cheers, Matt.
matt458 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
240D engine reving issue... xxxxxxDingo Joe W123 E,CE,D,CD,TD,TE Class 8 05-01-2008 11:01 AM
380sel not reving jonesy528 W126 S,SE,SEC,SEL,SD,SDL Class 2 08-09-2006 10:18 AM
Strange Reving Between Changes : ! woz W163 M-Class 4 05-01-2006 04:42 AM
What causes this intermittant reving? spongebobbill W126 S,SE,SEC,SEL,SD,SDL Class 3 11-04-2004 12:09 PM
86 300 e reving high at 60 mph Guest (MBNZ) W124 E,CE,D,TD Class 2 04-27-2001 08:26 PM
