Vito L113 Gas Problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-06-2007, 12:12 AM Thread Starter
Date registered: Aug 2007
Vehicle: Vito L
I have a strange problem with my Mercedes Vito L113, sometimes when it's running and I'm on the road, the gas pedal stops responding, I step on it and it does nothing. Turning the switch off and on again even without stopping fixes the problem, and it doesn't happen everyday, sometimes more than once a day, and sometimes once every three or four days.
I tried going to the Mercedes dealer maintenance shop and the computer diagnostics showed a problem in "fire 2 and 4", I'm guessing this means the spark plugs, but I tried changing them, and the coil that controls them and the problem wasn't fixed. The maintenance shop guy said he has no clue what could be causing this, so any advices or suggestions as to where to look would be much appreciated.
SalehYaman is offline
post #2 of 4 (permalink) Old 08-06-2007, 12:44 AM
Date registered: Aug 2006
Vehicle: Vito 113, X-Trail
Check your accelerator pedal box - there is a potentiometer inside that can go on the blink sometimes. Also, check the connectors there - could be a contact problem.
The 113 does not use the usual bowden throttle cable - since it's a drive-by-wire throttle.
leongster is offline
post #3 of 4 (permalink) Old 08-06-2007, 10:03 AM Thread Starter
Vehicle: Vito L
Thank you for your advise, I'll check that out, but can you please point me to where the "accelerator pedal box" is? Is it behind the pedal itself or in the front?
post #4 of 4 (permalink) Old 08-06-2007, 06:49 PM
It's connected to the accelerator pedal. There is a wiring harness attached to it. Check for corrosion in all the contacts. The potentiometers may also need some WD40.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Vito Throttle Problem YR1 V-Class 8 05-27-2014 11:42 AM
help with Vito 108 cdi problem please Pam3 V-Class 5 10-13-2006 01:49 PM
Vito 108CDI problem URGENT webwizard General Mercedes-Benz 1 10-24-2005 02:02 PM
problem with vito cdi 2.2 josip77 General Mercedes-Benz 1 10-24-2005 01:53 PM
Vito Starter problem dang2407 V-Class 0 01-31-2005 03:34 AM
