Mercedes Wiring Diagrams, Technical Schematics Etc - Page 3 - Mercedes-Benz Forum
post #21 of 273 (permalink) Old 07-26-2007, 08:00 AM Thread Starter
Sarge786's Avatar
Date registered: Apr 2005
Vehicle: V220 CDI 2003
Send a message via MSN to Sarge786
Injector Removal tool
Hi guys, I was surfing on the old net and came across this interesting tool, it is an injector removal tool and is available from a company called
www.fondera.co.uk
It costs about £136 and if it's good then it would be a hell of a lot of less trouble to get one and do your own vehicle as opposed to giving it to the dreaded Mercdads stealerships.
It is also being sold here :
MERCEDES VITO & SPRINTER IN-SITU INJECTOR REMOVAL TOOL on eBay Hand Tools, Garage Equipment Tools, Cars, Parts Vehicles (item 110152860766 end time 01-Aug-07 16:41:21 BST)
Anyone seen this or have one and can tell us if it is any good?
Sarge786 is offline
post #22 of 273 (permalink) Old 08-02-2007, 02:57 PM Thread Starter
Sarge786's Avatar
How to Fix Little Dents
To fix a single dent (like the one pictured), it is probably not worth the time and paperwork it takes to fill out the insurance claim. Besides doing it your is easy enough --the tools won't cost much, and the instructions won't make your head spin.
You can bang out that dent, fill those nicks, and refinish that paint job with a body hammer and dolly, a sander with a 36-grit disc to remove paint, a putty knife and body filler squeegees to apply filler, a bodyworking file ("cheese grater") to level the filler, a stroke sander to smooth it, an air compressor and spray gun to apply primer/surfacer/paint, and a buffer to shine it all up. Thanks to today's body repair materials-better paints, improved fillers and two-part primer/surfacers-bodywork and painting to a mirrorlike finish has never been easier to do in your own shop.
Bang it out
To remove a dent, first gain access to the back side of the body panel by removing items like headlight buckets, inner fenders, door panels and interior trim. Then, place a dolly on the outside of the dent and then hammer on the inside of the dent, striking the metal against the dolly. The key is to go slowly and work around the circumference of the dent, banging it out until it lies just below the undamaged area. After the dent is out, put the dolly on the inside of the dent, then tap the area surrounding the outside of the dent to knock in any high spots.
Prep & Apply Filler
When you're sure all the sheetmetal is just slightly below the surface of the surrounding area, use a disc sander with 36-grit paper to remove all paint and primer from the dent and surrounding area. This will give the body filler a rough surface (called tooth) to hang on to once it has hardened. After thoroughly mixing the filler with hardener, smooth it on the damaged area with a plastic filler applicator. The filler semihardens in 10 to 15 minutes to the consistency of cheddar cheese.
Sarge786 is offline
post #23 of 273 (permalink) Old 08-02-2007, 02:58 PM Thread Starter
Sarge786's Avatar
Continued...
Smoothdown & Sand Down Filler
At this point it's easy to smooth with a body file. Use the file to knock the filler down so it is slightly higher than the finished repair will be. After about 15 to 30 minutes, the filler becomes hard.At this point you can use a hand or air-powered stroke sander with 80-grit paper to bring the filler down to the level of the body. If you see any bright, shiny metal spots in or around the filler, those areas are high. Use the pointed (pick) end of a body hammer to tap them in slightly, then refill and resand.
Sarge786 is offline
post #24 of 273 (permalink) Old 08-02-2007, 02:58 PM Thread Starter
Sarge786's Avatar
Continued.....
Prime & Surface
Before the repaired area can be painted, scratches, pits and waves must be completely removed or they'll show up as reflections. A primer/surfacer forms a thick layer of material over the area, which is then sanded down to make the repair smooth and level. Two-part primer/surfacers, consisting of the primer and a hardening agent, allow a thick layer to be applied over the repair in only one or two coats. After a half-hour of drying the primer is ready for sanding.
(Warning! Before applying any primer or paint, be sure to wear a respirator rated for organic solvents.)
Sarge786 is offline
post #25 of 273 (permalink) Old 08-02-2007, 02:59 PM Thread Starter
Sarge786's Avatar
Continued....
Contrast paint the primer/surfacer
Before you sand, apply a light mist of black lacquer from a spray can over the repaired area. This contrast coating will reveal imperfections that will disappear as you sand. Make sure there is adequate ventilation, and also make sure that pilot lights and other flame sources in the general area are turned off.
Prep for Paint
To sand the primer, use a rubber sanding block and 400-grit waterproof sand paper. The trick is to sand lightly while frequently dipping the paper in a bucket of water to keep it clean. When all of the black contrast coat has disappeared, the repaired area is finished. Then clean and prepare the surface surrounding the repair to accept paint then wipe the entire panel with a solvent-based wax remover. Now, wetsand the area again to be painted with 600-grit waterproof sandpaper. If you're going to blend the paint into the original paint, make sure to sand an area larger than the area where you will be applying the paint. Thoroughly rinse the area, let it dry and then wipe again with wax remover. Mask off adjacent panels, then cover nearby wheels and major portions of the car with painter's plastic sheeting to shield it from overspray.
Paint
Mix the basecoat with the appropriate amount and type of solvent according to the maker's instructions. Before spraying, gently wipe the area to be painted with a tack rag, then spray the panel or repaired area. If you are blending, apply only enough basecoat to cover the repaired area, then taper off as you move away from the repair. After the basecoat has dried thoroughly, you'll notice its finish is quite dull. This is so the clearcoat will adhere tightly. Do not sand the basecoat before applying the clearcoat. After mixing the clearcoat with hardener, according to the manufacturer's instructions, apply a medium wet coat and let it flash dry 5 minutes or so before applying a second coat. After letting the clearcoat dry for an hour, remove all masking tape. Then wait one day before polishing.
Polish
Chances are the finish already looks pretty good. But to make it flawless, it pays to color-sand and polish the entire repair. Use 1500-grit sandpaper to flatten the finish, followed by rubbing compound to remove the scratches left by the sandpaper. Finish up with polishing compound to make the finish flawless. After polishing, wait one month to apply wax.
Sarge786 is offline
post #26 of 273 (permalink) Old 08-07-2007, 08:38 AM Thread Starter
Sarge786's Avatar
Regular Maintenance
Checking the Brake Fluid Level
Checking the Brake Lights
Checking the Vehicle Lights
Checking the Tyre Pressures
Checking the Coolant Level
Checking the Fluid Level in the Automatic Transmission
Service every 6000 Miles
Additional Service Every 12,000 Miles
Additional Service every 36,000 Miles
FAULT FINDING SECTION
ENGINE FAULTS
GLOW PLUG FAULTS
LUBRICATION SYSTEM FAULTS
DIESEL FUEL SYSTEM FAULTS
CLUTCH FAULTS
STEERING FAULTS
BRAKE FAULTS
ELECTRICAL FAULTS
SEE ATTACHMENT !
Sarge786 is offline
post #27 of 273 (permalink) Old 08-07-2007, 11:02 AM Thread Starter
Sarge786's Avatar
Info on Vito
Hi Guys there is someone selling this info on eBay, so I thought I'd put it here. Not a lot but there, but may help someone.
Evolutions of Mercedes Benz Vito (2003 - Present):
Year
Change or development
1996
Vito launched. Pay load 1,000 Kg.
2000
New diesel engine available: common rail TD2.2 diesel to accompany 2.0 petrol engine.
2003
Heavily revised Vito. Now just has CtD2.2 diesel engine. Payload now 1,015 - 1,080 Kg.
Specific Engine Checks for Mercedes Benz Vito (2003 - Present):
Area
What to look for
What it means
What to do
Injectors
1) Check that the van starts easily from cold or warm. 2) Once the engine has been running for a few minutes, smell around the cab and engine for diesel or oil fumes. If you turn the cab fan on full this will suck any fumes into the cab which can be a good test.
If the engine turns over but doesn't start the most common reason is the injectors (sticking open). If you can smell fumes, then the injector seals have failed and lead to a build up of carbon above the injectors.
When buying Negotiate a £600 discount or have the repair completed.
Glow plug
Check that the glow plug lights comes on with the ignition and goes out after about 5 seconds.
If the glow plug stays illuminated, the plugs need to be replaced.
When buying Negotiate a £400 discount or have the repair completed.
Specific Interior Checks for Mercedes Benz Vito (2003 - Present):
Area
What to look for
What it means
What to do
Steering
Turn the steering wheel from lock to lock and listen for a squeak or groaning noise. Also notice if the steering appears to be snatching as it turns.
These symptoms suggest that a front suspension strut, top mount or steering rack bush need to be replaced.
Have the van inspected to establish which it is.
Gears
Check that the gears change relatively easily. It is a cable-based system so will be a little notchy but should not be too stiff.
The gearbox needs to be repaired (usualyy a cable replacement) or the clutch may need to be replaced.
Specific Suspension Checks for Mercedes Benz Vito (2003 - Present):
Area
What to look for
What it means
What to do
Front tyre
Inspect the outside edges of the nearside front tyre. The legal limit for tread depth is 1.6mm above the base of the groove across 75% of the tyre.
The the nearside front tyre (especially the outer edge) wears quicker than the rest of the tyres.
Rotate the tyres around the vehicle regularly to increase their life.
Anti-roll bar links
As you drive the car over rough surfaces or bumps (e.g. speed bumps) listen for a knocking noise coming from the suspension.
A knocking noise from the suspension usually indicates that an anti-roll bar link needs replacing.
Negotiate a £200 discount or have the repair completed.
Recall History of Mercedes Benz Vito (2003 - Present):
Date
Model
Recall
25 Sep 1998
Built: 01/01/1996 - 31/12/1998
Tyre tread may become detached from the carcass. VINs: VSA638 000001 to 123462.
01 Jul 2000
The handbrake button may become sticky in operation and in certain circumstances may result in self release of the handbrake.
08 Aug 2003
A component inside the air bag control unit may become defective - Air bag may not deploy in a collision.
30 Jul 2004
Mounting of the foot operated parking brake pedal, may permit the mounting to become loose and in extreme cases, the assembly may become detached from the mounting bracket.
17 Aug 2004
It is possible that the engine speed may reduce or in extreme cases shut down due to a software error in the engine management unit.
08 Jun 2005
Built: 01/11/2003 - 31/10/2004
The clevis pin which secures the brake master cylinder push rod to the brake pedal cross shaft may become detached, due to the possible non-fitment of the securing clip.
Sarge786 is offline
post #28 of 273 (permalink) Old 08-16-2007, 06:03 AM Thread Starter
Sarge786's Avatar
Installing and removing the armrests
Swing the armrests up.
Press the
swivel hinge of the armrest against the backrest and as you do so
pivot the armrest back by about 45°. The armrest can be removed in this
position. Cover the armrest socket with the appropriate caps.
To install, place the armrest into the socket in the 45° position - the unit may
otherwise be damaged. Press the swivel hinge gently against the backrest
and pivot the armrest forwards.
Note:
Do not use force when fitting or removing the armrests.
Regards
SARGE
Sarge786 is offline
post #29 of 273 (permalink) Old 09-11-2007, 04:16 AM Thread Starter
Sarge786's Avatar
Auto Repair for Dummies *CAR GUiDE*
Auto Repair For Dummies is indispensable for anyone who is tired of nodding and smiling at the incomprehensible mutterings of your mechanic, only to end up shelling out money for repairs that you neither fully understand nor always need. This easy-to-understand guide is also for you if you:
* Don't have the vaguest idea of how a car works?
* Can't identify anything you see under the hood of your vehicle?
* Are tired of other people assuming (especially if you’re a teenager or a woman) that you aren’t capable of handling repairs yourself?
* Don't want to feel helpless in an emergency?
* Are tired of being ripped off because of your own ignorance?
This book shows you how your car works; what it needs in the way of tender loving care; and how to keep from being overcharged if you need to entrust repairs to someone else. By handling the simple maintenance and tune-ups and being able to diagnose trouble and perform the less complex repairs yourself, you’ll save some serious money.
Once you read this, you will carry out basic car repair and maintenance with confidence and ease.
download it from here:
RapidShare: 1-Click Webhosting
Sarge
Sarge786 is offline
post #30 of 273 (permalink) Old 09-11-2007, 07:04 AM Thread Starter
Sarge786's Avatar
Car PC Hacks
By Damien Stolarz
Publisher: O'Reilly
Pub Date: July 2005
ISBN: 0-596-00871-6
Pages: 382
A car PC or carputer is a car tricked-out with electronics for playing radio, music and DVD movies, connecting to the Internet, navigating and tracking with satellite, taking photos, and any electronic gadget a person wants in a car. All these devices are managed and controlled through a single screen or interface. The only place car PC enthusiasts can go for advice, tips and tools is a handful of hard-to-find Web sites--until now. Car PC Hacks is your guide into the car PC revolution.
Packing MP3 players, handheld devices, computers and video-on-demand systems gives you a pile too heavy to carry. But add a car and put them together, you've got a powerful and mobile multimedia center requiring no lifting. The next time you give kids a lift, you won't hear, "Are we there yet?" Instead, expect "We're there already?" as they won't want to leave the car while playing video games from multiple consoles.
Car PC Hacks is the first book available to introduce and entrench you into this hot new market. You can count on the book because it hails from O'Reilly, a trusted resource for technical books. Expect innovation, useful tools, and fun experiments that you've come to expect from O'Reilly's Hacks Series.
Maybe you've hacked computers and gadgets, and now you're ready to take it to your car. If hacking is new and you would like to mix cars and computers, this book gets you started with its introduction to the basics of car electrical systems. Even when you're unclear on the difference between amps and watts, expect a clear explanation along with real-life examples to get on track. Whether you're venturing into car PC for the first time or an experienced hobbyist, hop in the book for a joy ride.
Download:
Code:RapidShare: 1-Click Webhosting
Sarge
Sarge786 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Wiring Schematics enJOYment W126 S,SE,SEC,SEL,SD,SDL Class 3 05-05-2009 02:27 PM
Does anyone have the wiring schematics for W126 seat switches? MS Fowler Off-Topic 2 01-02-2006 07:35 PM
needed: 463 wiring schematics mserpe G-Class 5 11-17-2005 09:31 AM
W460 Wiper Motor Issue (wiring schematics) mserpe G-Class 1 11-16-2005 12:36 PM
Anyone have wiring diagram and or schematics? (more) Chris Krikorian W163 M-Class 6 01-24-2002 07:09 PM
