Front Plate No Holes Mounting - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-02-2019, 12:30 PM Thread Starter
Darkmann's Avatar
Vehicle: 05 500
Quoted: 105 Post(s)
MY15 SL400
I have been meaning to post this for a while but kept procrastinating. Unfortunately I don't have pics, but it's pretty simple to mount the front plate without holes on the bumper.
OEM comes with a plug which is screwed in the center of the plate bracket. At the back, that plug clips on the front grille. The bracket also has two attachment points at the top - no plugs. Those screw to the front bumper, messing up the bumper.
I purchased two additional plugs (darn things aren't cheap!) which I attached to the two top holes on the plate bracket. I used two long stainless screws (2.5 inches I believe) and a spacer to position the plate bracket away from the bumper body. I used a lawn mower fuel hose for spacer (cut to length). I use the fuel hose for strength and outdoor durability. Use whatever hollow material you can find. Just make sure it can be cut easily because you may have to try several lengths to get get your preferred distance from bumper.
Process:
  1. Play with plugs on back of plate bracket to locate proper attachment to grille
  2. The two SS screws go through the two top holes (may work holes to slight elliptical shape to make things easier). I used SS screws to avoid rusting over time. Used a drill to reshape holes on plate bracket.
  3. At back of mounting plate, insert spacer on screw
  4. Screw assembly to plugs - hand tight
  5. Place assembly (plugs/spacer/plate) on location from Step 1 on front grille - may not locate perpendicular to grille, but that's not an issue
  6. Rework spacer as necessary until desired clearance is achieved - you will have to take everything apart, cut new spacer to length and start all over
  7. Push plugs through grille opening located in Step 1
  8. Torque screws to desired strength - not too tight, just enough to hold bracket solidly in place
  9. Mount front plate
Mine sits solidly with no problems at all. Car is in winter storage. I'll take pics if anyone needs them.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R231 SL-Class
No holes front bumper plate solution - DIY 33zero W212 E-Class 8 02-10-2014 08:30 AM
G Class German Engineered Front License Plate Frame MBG500fan G-Class 0 06-11-2013 09:20 AM
406 Front and Rear winches *lots of pics* Spicergear Unimog 21 10-04-2012 12:55 PM
Front License Plate frame.. What to do? C300Brett R/C107 SL/SLC Class 6 12-24-2010 06:02 AM
Digital ACC / Smoker Delete / No Holes Front Plate... BF_JC230 W203 C-Class 14 10-21-2008 08:15 AM
