Hydraulic pipe in trunk : Which one - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-30-2017, 06:29 AM Thread Starter
Date registered: Mar 2007
Vehicle: R231 2012 SL500
I've started to add the option 881, which is the automatic trunk close, on a 2012 R231 SL500
It use two hydraulic cylinder (one on both side), which are used to open or close the trunk. Each cylinder has 2 pipes which are connected to the hydraulic pump.
There is, on each pipe, a number printed in white, in order to be able to connect the right pipe at the right position.
Unfortunately, the same number is not written in the cylinder : i dont know where to connect the pipe.
On left pipes, one has 71, the second one has 81
On right pipes, one has 75, the second one has 85.
Can you check on your car which one is connected on the lower part of the left cylinder, and same for the righ cylinder ? It will help me a lot.
I will add picture to be more clear.
Michel
zeiser50 is offline
post #2 of 5 (permalink) Old 06-30-2017, 11:14 AM Thread Starter
Correction : left pipes are 071 & 081, right pipes are 070 & 080
zeiser50 is offline
post #3 of 5 (permalink) Old 06-30-2017, 11:24 AM Thread Starter
Which is the right one for the lower connection of the cylinder, left & right ?
zeiser50 is offline
post #4 of 5 (permalink) Old 07-08-2017, 01:57 PM
Thorgod's Avatar
Date registered: Jul 2005
Vehicle: 2013 SL550 Grey/ Red/Black Ash wood with every option
Quoted: 7 Post(s)
Zeiser, I attached left & right side pics of my 2013SL500. I hope this helps,
Thorgod
Name:	2013 SL550 LFT SIDE.jpg
ID:	2207186   Click image for larger version
Name:	2013 SL550 RT SIDE.jpg
1971 350SL 4-speed stick- sold
1979 300CD- sold
1979 450SL (Euro)- sold
1985 300D- sold
1989 560SL- sold
1994 E320 wagon- sold
1995 SL500- 46,000 mi.- sold
2004 Land Rover Discovery- sold
2009 SL550- Silver Arrow- 26,275 miles- sold
2013 SL550-
Thorgod is offline
post #5 of 5 (permalink) Old 03-03-2019, 10:11 PM
Date registered: Mar 2019
Vehicle: 2015 sl400
Michel, how do you bleed the air out of the lines?
Albert60 is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R231 SL-Class
