Telephone no power - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-25-2019, 10:14 AM Thread Starter
Date registered: Jun 2019
Telephone no power
I recently bought an 04 SL500 Mercedes Benz. It is equipped with a phone/cradle in the armrest but there is no power to the cradle. I purchased the compatible puck which is a Motorola V60 puck but have no power. When I select Telephone on the system it says error no phone. Mercedes dealerships says that it can't be powered up. Is this true?
jdwayne1 is offline
post #2 of 4 (permalink) Old 06-26-2019, 06:17 AM
kbob999's Avatar
Date registered: Aug 2013
Vehicle: 2003 SL55; 2011 E350 BTC
Quoted: 71 Post(s)
Does not sound true to me. I’m sure you can get power to the puck, but not sure you can get the phone to work. It may have been disconnected from the fiber optic loop, but you can check that later.
Start with the simple, like a fuse to the cradle. Search for”Fuse Map” and you’re good to go. Likely behind passenger seat. See if there is power at the fuse, and the fuse is good. Blown fuses normally mean something has a short, so it can blow again.
You may want to get a WIS (work instruction) CD off eBay and install it on a laptop.
This will give you tons of info on how to analyses systems, trace wires and trouble shoot. Only about $10.
Or if you consider this car a keeper, get an SDS and learn how to use it. Will pay for itself many times over the life of the car.
'11 E350 Bluetec P2 Sport 55K Mi.
'03 SL55 AMG Pano 95K Mi.
kbob999 is offline
post #3 of 4 (permalink) Old 06-26-2019, 08:00 PM Thread Starter
How do I find out if its disconnected from Fiber Optics? Hope can I get it reconnected?
jdwayne1 is offline
post #4 of 4 (permalink) Old 06-27-2019, 07:06 AM
kbob999's Avatar
Quoted: 71 Post(s)
If the phone is disconnected, there will be a fiber optic splice in the line, and the phone will be removed on SDS list of devices in the loop.
You canít just disconnect the fiber line and yank the phone out, as the loop must be complete for the fiber devices to work.
Get the power issue resolved, then work on the communication issue next.
kbob999 is offline
