front-end is out --- with pictures - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-20-2019, 09:32 AM Thread Starter
Date registered: May 2019
Vehicle: 2005 sl500
Quoted: 4 Post(s)
so brought a sl500 with 20 thousand miles. the car was hit in the front. small hit { in my opinion }. im going to do the face lift since i have to change the front anyway. Since the car is completly apart what preventive maintenance should i do to it before i put it back together ? I already change the thermostat and belt. i want to change the abc and power steering fluid with filter but i want to do the rodeo thing but i dont have a mb start computer. I do have a maxicheck pro. would i be able to do it with that one ? guys anyyyyyy help will be appreciate. i had to replace radiator and ac condenser. i leave in north jersey .
ID:	2522570   Click image for larger version
ID:	2522572   Click image for larger version
vmarcial27 is online now
post #2 of 9 (permalink) Old 06-20-2019, 09:44 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 596 Post(s)
Probably not.
But why listen to me? How much time and effort does it take to plug your Maxicheck Pro into the OBD-II connector, turn the ignition key on, and try to communicate with the ABC controller and find out if there exists a menu item to activate Rodeo?
bobterry99 is offline
post #3 of 9 (permalink) Old 06-20-2019, 10:01 AM Thread Starter
Vehicle: 2005 sl500
Quoted: 4 Post(s)
yes you are right. im going to try when i get home. what else should i do before i put everything back ?
post #4 of 9 (permalink) Old 06-20-2019, 11:56 AM
kbob999's Avatar
Date registered: Aug 2013
Vehicle: 2003 SL55; 2011 E350 BTC
Quoted: 71 Post(s)
With only 20K miles on the car...not much.
There are items that can be age related, rather than miles, and I'd be inclined to change all the fluids. You can do this after assembly.
Unless there damaged items I'd say put it together and drive it.
kbob999 is online now
post #5 of 9 (permalink) Old 06-20-2019, 12:13 PM Thread Starter
Vehicle: 2005 sl500
Quoted: 4 Post(s)
perfect thanks . pentosin chf 11s for power steering and abc right ?
post #6 of 9 (permalink) Old 06-20-2019, 12:32 PM Thread Starter
Vehicle: 2005 sl500
Quoted: 4 Post(s)
what is the differences betwen this 2 ?
ID:	2522600   Click image for larger version
post #7 of 9 (permalink) Old 06-20-2019, 12:53 PM
kbob999's Avatar
Quoted: 71 Post(s)
They are the same.
post #8 of 9 (permalink) Old 06-23-2019, 08:31 PM
Date registered: Jun 2018
Vehicle: 2005 SL65 plus 13 other non MB toys
Quoted: 90 Post(s)
I would suggest replacing all of the dampers as PM. Time takes their toll on them. FCPEuro sells them as a set with a lifetime guarantee. Also, closely inspect any hydraulic line you can get to. If you detect ANY sort of leak or weeping, replace or repair it while you have access.
Before putting it all back together, get the area as clean as you can to make it easier to detect any leaks in the future. Grime absorbs fluid and makes it very difficult to detect leaks.
Maybe replace the crank position sensor (FCPEuro again) and keep the one you remove as a spare in the car should you get stranded. Very cheap insurance.
Triple cranks is offline
post #9 of 9 (permalink) Old 06-23-2019, 09:19 PM
Date registered: Mar 2018
Vehicle: sl600
Quoted: 12 Post(s)
Hey if you do a face lift, document it please, not to many of those on here but many people would like to do it too, so we'll all know the common problems you might encounter. And what budget is necessary and best parts recommended. Thanks
sl600kid is offline
