stuck wheel - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-16-2019, 08:36 AM Thread Starter
Date registered: Dec 2017
Vehicle: 2007 SL550
stuck wheel
Changing tire..2007 SL550 front wheel wont come off
tfyork47 is offline
post #2 of 7 (permalink) Old 04-16-2019, 09:11 AM
kbob999's Avatar
Date registered: Aug 2013
Vehicle: 2003 SL55; 2011 E350 BTC
Quoted: 68 Post(s)
Are all the 5 bolts removed?
Hub may be rusted to the wheel. Remove the center cap and squirt some penetrating oil in center. Spin the wheel a couple times. Let it sit for 5 minutes. Push in hard at the top of the wheel toward the center of the car.
When it is off, clean and remove the rust from both surfaces. Apply a light film of grease, then reassemble.
'11 E350 Bluetec P2 Sport 55K Mi.
'03 SL55 AMG Pano 95K Mi.
kbob999 is offline
post #3 of 7 (permalink) Old 04-16-2019, 08:18 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1624 Post(s)
Another trick is to put the bolts back on and then loosen them by a few threads. Then, carefully drive the car a few feet until the wheel breaks loose.
- RODNEY
My Stable:
rudeney is offline
post #4 of 7 (permalink) Old 04-17-2019, 06:26 AM
Gary Knox's Avatar
Date registered: Nov 2013
Vehicle: 2003 SL55 AMG, 1994 Porsche 928 GTS, 2007 Audi A8, 1990 MB 560 SEC
Quoted: 41 Post(s)
Slight modification to Rodney's suggestion. You probably won't even need to drive the car when it is a front wheel. Might need drive and turn a corner with a rear wheel.
Usually, if you loosen the bolts 1 or at most 2 turns from full torque on a front wheel, then with the tire tire in firm contact with the floor, start the engine and turn the steering wheel both ways to full lock it will pop loose, but still be held in place by the bolts. On one or two occasions when I've had this issue, it has taken 2 or 3 turns each way. Finally, just jack it back up and remove the bolts and the wheel.
I like Kbob999's suggestion for maintenance before remounting a wheel. I like to put a thin coat of Anti-Seize on all mating surfaces after any residual rust has been removed.
Gary
rudeney and Triple cranks like this.
Gary--
'03 MB SL55 AMG - Sophie
'07 Audi A8 - Audrie
'97 BMW 840Ci - to be named later
'74 BMW 3.0 CSi - Lorelei
'94 Porsche 928 GTS - Recently departed to OR
'90 MB 560 SEC -Brunhilde, recently moved to Maine
Gary Knox is offline
post #5 of 7 (permalink) Old 04-21-2019, 02:15 PM
4DGeorge's Avatar
Date registered: Jan 2018
Vehicle: 2006 S500 (W220, Designo Espresso, AMG Sport, LWB)
Quoted: 37 Post(s)
Ditto to anti-sieze compound on hub mating surface.
4DGeorge is offline
post #6 of 7 (permalink) Old 04-21-2019, 07:34 PM
OKB
Date registered: Jun 2016
Vehicle: 13 SL63
Quoted: 27 Post(s)
give the wheel and hub a good sanding. Its very close tolerance
OKB is offline
post #7 of 7 (permalink) Old 04-22-2019, 06:37 PM
Date registered: Jun 2018
Vehicle: 2005 SL65 plus 13 other non MB toys
Quoted: 76 Post(s)
I too have used the method of loosening the bolts. Worked every time 😉
Triple cranks is offline
Nardi Dilemma bigsky R/C107 SL/SLC Class 116 08-14-2017 08:01 PM
Carbon fiber steering wheel install LRDog R230 SL-Class 1 12-22-2014 04:21 PM
AMG steering wheel Bazzle R170 SLK-Class 22 04-26-2012 05:10 PM
4x4 and lockers How it works on GW463? rey445588 G-Class 5 02-04-2008 11:10 AM
A great experience with a wheel repair shop ... leepy55 W211 E55 AMG, E63 AMG 1 10-13-2007 05:09 PM
