trunk open warning light - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-13-2019, 03:54 PM Thread Starter
Date registered: Jan 2011
Vehicle: 2009 SL550 Silver Arrow
Quoted: 4 Post(s)
Question trunk open warning light
The red light on the trunk control button on the driver's door and warning light stay on even though the trunk closes and latches normally. The most annoying aspect of this is that it prevents the top from opening. Has anyone else encountered this? Searching around this was the closest match I could find:
https://www.cargurus.com/Cars/Discus...32392_ds722203
I'll try adjusting the latch but the on one on the button is quite rigid and I'm a bit worried about fiddling with the one on the trunk lid since the soft close mechanism is there.
TIA!
brownboy2 is offline
post #2 of 4 (permalink) Old 04-13-2019, 06:22 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1663 Post(s)
The pneumatic "pull down" function of the latch is not working. It's almost certainly due to a leak in the plastic sections of the latch. This will help:
https://mbworld.org/forums/sl-class-...w-fix-diy.html
In the mean time, try pulling fuse 71 for a minute to reset the PSE pump. You may be able to get the latch to pull down once or twice, but it will eventually shot down the circuit again due to extended run time of the PSE pump.
- RODNEY
My Stable:
rudeney is offline
post #3 of 4 (permalink) Old 05-21-2019, 08:23 PM Thread Starter
Quoted: 4 Post(s)
Thanks Rodney for your typical fast, helpful response. My apologies on not posting my outcome earlier but I ended up going to my Indy right before a long vacay.
The latch was indeed not functioning and they replaced it. I know it will eventually fail again but the first one lasted over 10 years with me using it a lot. They said it took several hours of tracing and I thought the notes were mildly interesting:
Reported that trunk lid warning is on in the display and vario roof will not operate
Scan all systems with xentry diagnostics. No fault codes present.
Test trunk latch operation using actual values in xentry diagnosis.
Found incorrect trunk latch switch operation.
With the trunk latch removed, found the trunk latch switches work, but the trunk latch vacuum housing are cracking.
Replace trunk latch but still not functioning.
Trace trunk latch circuits further. Found open circuit in the trunk lid wiring harness.
Access harness as necessary and repair defective wiring.
Confirm correct operation of trunk latch and vario roof.
At first they thought the replacement latch might by faulty and when I talked to the technician at the end he said there's a wiring harness that gets stressed some when the trunk lid is operated but gets more stress when the vario roof operates and that there was a break inside one of the wires so he had to probe them manually to find it. I told him that I do operate the roof a lot (a few hundred times a year). Is there a way to get a count for that?
What I don't know is that if I did the DIY fix if I would have gotten stuck because of this wiring harness issue or if somehow they caused that problem but I figure I should share my experience here. Ended up costing me $1100. My SL is 11 years old this month and I understand that not being able to DIY makes things (much) more expensive at times but this forum is great!
post #4 of 4 (permalink) Old 05-22-2019, 10:58 AM
rudeney's Avatar
If the wiring harness was defective, then the repair would likely had not worked.
- RODNEY
My Stable:
rudeney is offline
Blower fan inop...94 S500 Doni W140 S-Class 2 05-30-2018 02:44 AM
Cold air blowing out of defrost vent albert W140 S-Class 5 10-06-2016 06:06 AM
2004 E320 - Red Battery "Visit Workshop" - Is it the Relay or Main battery ccrobin W211 E-Class 10 11-20-2015 03:25 AM
W202 A/C Diagnostics This is a long one! RobertCarew W202 C-Class 1 08-15-2013 06:59 PM
Rear SAM? Electrical issues/dealer screw ups? (long) bob loblaw C209/A209 CLK-Class 3 04-07-2013 08:54 AM
