ABC Valve Block Removal - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-21-2019, 12:51 PM Thread Starter
Date registered: Jul 2016
Vehicle: 2005 R230 SL500
Quoted: 7 Post(s)
I have read all the ABC valve block threads and do not see if anyone has been able to use the Mercedes disconnect tools on the quick snap connectors for the hydraulic lines to the valve blocks?
Tool part numbers are W 230 589 01 33 00 and W 221 589 01 33 00
I did the rear valve block rebuild on my 2005 SL500 last year and believe disconnecting these lines would help a lot.
hotboat likes this.
Pat_Opsahl is offline
post #2 of 5 (permalink) Old 01-21-2019, 12:56 PM Thread Starter
Quoted: 7 Post(s)
Added attachment of tools
post #3 of 5 (permalink) Old 07-21-2019, 02:12 PM
Date registered: Apr 2014
Vehicle: 2003 SL 500
Quoted: 2 Post(s)
Quick Connect Tool
Considering the date that you sent this, I am sure that you must have figured this out. I found this thread after I had followed the instructions posted on this site for removing the rear valve block and rebuilding it while replacing both accumulators. I learned a lot but I have you to thank for turning my head to the job of a smarter method of reinstalling it.
This lead me to your post. I started life as a Heavy Duty Mechanic who did a lot of work on Caterpillar equipment and hydraulics. As soon as I read your post, I looked carefully at the quick connects, swore at myself for not identifying them sooner before walking into my shop and taking an old 14 mm open ended wrench and grinding it down to 4 mm in thickness so it would work just like the tool that you pictured. I then slipped it into the slot and gripped the black fitting on the steel line and the wrench pulling them towards each other until the collar ring that the wrench was pulling up on moved and released the fitting - very similar to connecting and disconnecting an air tool. I was then able to pull the hose away from the steel line. I was able to assemble all the steel lines on the valve block on the bench and then install it easily by sliding it into place and reconnecting the hoses with the quick connects, I will post this process with better pictures in the appropriate thread.
Thank you for making me think before I did the rest of the ABC system overhaul.
ID:	2529572   Click image for larger version
mercy-me and DamoneGra like this.
Starfleet56 is offline
post #4 of 5 (permalink) Old 07-22-2019, 07:35 AM Thread Starter
Quoted: 7 Post(s)
Re: ABC Valve Block Removal
Glad to hear the job was made easier.
After I bought the rebuild kit and tools, I did not rebuild the Valve Block because my care stopped sinking down overnight. I am not sure why?
post #5 of 5 (permalink) Old 07-23-2019, 04:10 AM
Date registered: Jun 2018
Vehicle: 2005 SL65 plus 13 other non MB toys
Quoted: 90 Post(s)
A piece of dirt or debris was probably lodged in the valve block. It must have dislodged and by all rights is now residing in your ABC filter . Check your fluid. If it is getting brown in color, it is time to do a flush and filter change.
Triple cranks is offline
