Warning wheel air presion sensor not detected - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-28-2018, 05:44 PM Thread Starter
javiervcia's Avatar
Date registered: Dec 2009
Vehicle: SL500 R230 - AUDI A8 D3 - RANGE ROVER CLASSIC 3.9 V8
Quoted: 5 Post(s)
Hello friends
I have a fault in my R230, some times have on screen " wheel air sensor not detected, please reset"
This is a normal fault because i remove the air sensor from the wheel, is possible by star diagnose or other way remove this warning and not use this function?
Thanks
Enviado desde mi SM-G965F mediante Tapatalk
javiervcia is offline
post #2 of 10 (permalink) Old 12-29-2018, 06:39 AM
kbob999's Avatar
Date registered: Aug 2013
Vehicle: 2003 SL55; 2011 E350 BTC
Quoted: 67 Post(s)
Yes. The SDS can change the setting to ‘not present’ which will disable the wheel sensor function.
javiervcia likes this.
'11 E350 Bluetec P2 Sport 55K Mi.
'03 SL55 AMG Pano 95K Mi.
kbob999 is offline
post #3 of 10 (permalink) Old 01-06-2019, 03:10 PM Thread Starter
javiervcia's Avatar
Quoted: 5 Post(s)
Great :-)
Thank you for the answer
post #4 of 10 (permalink) Old 03-23-2019, 08:51 AM Thread Starter
javiervcia's Avatar
Quoted: 5 Post(s)
Ok
Perfect
Now disconected
Thanks
Enviado desde mi SM-G975F mediante Tapatalk
post #5 of 10 (permalink) Old 03-24-2019, 12:17 PM
Date registered: Jan 2019
Vehicle: 2003 MB SL500
I just did the same thing yesterday. I hate TPMS systems. You should be checking tire pressure and fluid levels regularly anyway if you plan to own a car like this. And in the case of a catastrophic blowout, the TPMS system isn't going to be any help anyway. While I was at it I deactivated the "Key Card" prompt since I don't have the key card for the car, and the SOS mobility system. It's nice having no error codes on the display cluster while driving!
If you don't have a STAR Diagnostic system and work on your own SL - GET ONE!
Mattleycrue76 is offline
post #6 of 10 (permalink) Old 03-24-2019, 12:32 PM
50annsl's Avatar
Quoted: 6 Post(s)
So when you disable it through SDS the low pressure sign don't come on the instrument cluster. I will have my indy do it rather than buy another set
50annsl is offline
post #7 of 10 (permalink) Old 03-30-2019, 04:50 AM
Herman K's Avatar
Date registered: Jul 2011
Vehicle: 2006 S55 AMG - 2007 SL55 AMG P030
Quoted: 19 Post(s)
However...
Originally Posted by javiervcia View Post
Ok
Perfect
Now disconected
Thanks
Disconnecting on a temporary basis may be fine, I have found that working TPMS sensors in the wheel have saved me several times from keeping on driving when a tire goes out and may damage my expensive rims.
I have found that an original set of (4) sensors in only $100 so I'm going to replace mine in due time (with my next tire change) after they arrive.
BTW; I enjoyed driving the rental car from Barcelona-Alicante would love to have had my SL there to do this (beautiful roads)
Herman K is offline
post #8 of 10 (permalink) Old 03-30-2019, 07:09 AM
50annsl's Avatar
Quoted: 6 Post(s)
I also later found a set on eBay for 100 and got it. They look new. At this cost it’s worth it.
50annsl is offline
post #9 of 10 (permalink) Old 03-30-2019, 07:28 AM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1605 Post(s)
I hate the "low cost" TPMS system s that just give you an idiot light. Those seem to always trigger on the first cold days. Now, the "high line" systems with individual reads per tire are useful and I find them to be very accurate. I had a cracked rim that would leak down over about a week so it was great to be able to keep an eye on it until I had it repaired.
- RODNEY
My Stable:
rudeney is offline
post #10 of 10 (permalink) Old 03-30-2019, 07:35 AM Thread Starter
javiervcia's Avatar
Quoted: 5 Post(s)
Hi Herman
The road from Barcelone to Alicante is a highway? I not sure if is beautiful...haha
The old road from valencia to Alicante is more beautiful
You have available my SL500 for enjoy.....
