Rear Differential Service - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 12-11-2018, 06:58 PM Thread Starter
pfarah77's Avatar
Date registered: Sep 2015
Vehicle: 2008 SL550
Quoted: 41 Post(s)
Hey All,
Just wondering if anyone knows the part number for the rear diff fill and drain plugs. I'm going to perform that service over the next week or so as the plugs are quite buggered up & rusty. Thanks.
pfarah77 is offline
post #2 of 19 (permalink) Old 12-12-2018, 07:04 AM
kbob999's Avatar
Date registered: Aug 2013
Vehicle: 2003 SL55; 2011 E350 BTC
Quoted: 71 Post(s)
Here's a link to OEM parts for your car.
https://www.mbdirectparts.com/auto-p...-v8-gas-engine
I was not able to find the drain or fill plugs with a search. Maybe your luck will be better.
'11 E350 Bluetec P2 Sport 55K Mi.
'03 SL55 AMG Pano 95K Mi.
kbob999 is offline
post #3 of 19 (permalink) Old 12-12-2018, 10:43 PM
Ruindr's Avatar
Date registered: Mar 2015
Vehicle: 2007 CL600, 2003 SL55AMG, 1987 560SEL ECE, 1985 280SL
Quoted: 409 Post(s)
Part number A3529970032 X 2
See attached screenshots from EPC.
ID:	2472536   Click image for larger version
Stay flexible - keep smiling
Ruindr is offline
post #4 of 19 (permalink) Old 12-13-2018, 03:38 AM Thread Starter
pfarah77's Avatar
Vehicle: 2008 SL550
Quoted: 41 Post(s)
Exactly what I was looking for, thanks!!
pfarah77 is offline
post #5 of 19 (permalink) Old 12-14-2018, 03:11 PM Thread Starter
pfarah77's Avatar
Vehicle: 2008 SL550
Quoted: 41 Post(s)
Hey, another question!
The procedure calls for the use of Omnifit 100H Sealant (one drop on the drain/fill plugs). Can Loctite 577 Thread Sealant be substituted? It's much easier to source... Thanks.
pfarah77 is offline
post #6 of 19 (permalink) Old 12-16-2018, 05:18 AM
kbob999's Avatar
Quoted: 71 Post(s)
I would have no problem using the Locktite product for this application.
kbob999 is offline
post #7 of 19 (permalink) Old 12-16-2018, 10:01 AM Thread Starter
pfarah77's Avatar
Vehicle: 2008 SL550
Quoted: 41 Post(s)
577 or do you have another number in mind?
pfarah77 is offline
post #8 of 19 (permalink) Old 12-16-2018, 10:12 AM
kbob999's Avatar
Quoted: 71 Post(s)
I like the specs on the 567 better, but I think both will work. You are only trying to keep seepage to a minimum with the sealant. Teflon tape would work too in my opinion.
kbob999 is offline
post #9 of 19 (permalink) Old 12-16-2018, 01:58 PM
mercy-me's Avatar
Date registered: Apr 2012
Vehicle: 2003 SL500, 2012 E350 4Matic P2
Quoted: 64 Post(s)
I used the tape. No pressure to seal against just seepage. No leaks on three different car diff services.
Bob
Sold:
2001 W220 S430
1991 BMW E32 750IL V12
mercy-me is offline
post #10 of 19 (permalink) Old 12-17-2018, 06:56 AM
Gary Knox's Avatar
Date registered: Nov 2013
Vehicle: 2003 SL55 AMG, 1994 Porsche 928 GTS, 2007 Audi A8, 1990 MB 560 SEC
Quoted: 41 Post(s)
There is also a Teflon paste used by plumbers that is impervious to oils. I've used this many times on differential, transmission, and engine oil drain (and fill) plugs. Never any leaks, and if needed, the plug is easy to remove 'next time'. Comes in a small container with brush. 10X lifetime supply for our use!!
Gary
Gary--
'03 MB SL55 AMG - Sophie
'07 Audi A8 - Audrie
'97 BMW 840Ci - to be named later
'74 BMW 3.0 CSi - Lorelei
'94 Porsche 928 GTS - Recently departed to OR
'90 MB 560 SEC -Brunhilde, recently moved to Maine
Gary Knox is offline
