Very early 07/2002 SL55 SWI-RC by PAC steering controller for upgrades head unit que - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-17-2018, 01:45 AM Thread Starter
ADRIAN126sec's Avatar
Date registered: Dec 2008
Vehicle: 99CL600,98CL600 Swiss import,R230 SL666, EURO1985 280 CE & XR600R Desert killer
Quoted: 32 Post(s)
Hi there wondering if anyone with early R230 with D2B wiring had successfull connection to Can B with SWI-RC steering controller for upgraded head unit I’m wondering how to do it ? to have up and down volume buttons operable from steering wheel what’s the right way to do it ?
ADRIAN126sec is offline
post #2 of 6 (permalink) Old 09-18-2018, 04:46 PM Thread Starter
Quoted: 32 Post(s)
Bump !!!
post #3 of 6 (permalink) Old 09-18-2018, 06:13 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1690 Post(s)
I don't think it matters if it's "very early" - just that it's the pre-MY2005 facelift version that uses the older CAN bus protocol. They may sell it as for "D2B" fiber, but actually, it does not use the fiber connection, just the CAN interface. But the CAN changed along with the conversion from D2B to MOST fiber in MY2005.
- RODNEY
My Stable:
rudeney is offline
post #4 of 6 (permalink) Old 09-18-2018, 06:19 PM Thread Starter
Quoted: 32 Post(s)
yes that’s true and I just need to find right Can Bus interface for 2003 SL and seems like there is none or no one tested yet but it could fit from SLK or C classes from or even S classes from Same Era but I’m not sure if protocols will be same ? Probably not that’s why SWI-CAN2 supports other Mercedes from that era but not SL 😞 so not sure if I should waist money to find out it won’t work or it will work since it’s for Can bus output but just wasn’t tested on SL R230
post #5 of 6 (permalink) Old 09-18-2018, 07:45 PM
rudeney's Avatar
The CAN bus protocols are the same across models, so there's nothing special about the SL.
- RODNEY
My Stable:
rudeney is offline
post #6 of 6 (permalink) Old 09-18-2018, 09:02 PM Thread Starter
Quoted: 32 Post(s)
I hope so that’s what I thought because why it’s supported with other mercedes but just not SL it’s funny when I tried car fittment it would take old slashes like 2000 2001 and up and C classes and others but not SL ! I was just hoping to find someone who went thru same crap and see his opinion on that well I might just get SWI-CAN2 and see worse case it won’t work and I’m not going to have volume + - from steering wheel !
