SL55 and all M113K heat sink problems !!! Need your opinion ? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-29-2017, 10:32 PM Thread Starter
ADRIAN126sec's Avatar
Date registered: Dec 2008
Vehicle: 99CL600,98CL600 Swiss import,R230 SL666, EURO1985 280 CE & XR600R Desert killer
Quoted: 32 Post(s)
Hi Gang I'm doing few upgrades on my M113 K motor like bigger pulleys, bigger throttle body ,split supercharging cooling etc ,and I want to wrap SC cooler which is barried in V-block valley other words Death Valley LOL I'm going to use DEI reflective GOLD tape which is available on eBay and now to get even better results I was thinking to use bigger sheet (blanket ) to put in V-Channel as well but now since cooler would be wrapped already there shouldn't be much harm on it from heat sink and on the other hand if block would be wrapped too there would be no heat transfer to space between block and the whole supercharger with cooler ,and whole heat would be trapped in block itself and here is my question what should I do cuz wrapping just cooler is ok keep just away from heat ,but engine block on the other hand might be risky to keep the heat trapped and not being transferred. All help would be much appreciated
ADRIAN126sec is offline
post #2 of 5 (permalink) Old 01-30-2017, 06:43 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 324 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
There are many things you can do before wrapping components (not as effective, and prevents components from self cooling against air in the engine compartment, not good for sleeves, harness, plastic components... etc.
Look into integrating ice tank, AC cooling, intake wax spacers... etc.
These solutions decrease comfort and reliability, but extreme performance call for extreme solutions...
should be fine if the car is not a daily driver...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X166 GL CLass GL63 (///AMG)
Ducati 999 with Termignoni and CF
Former Mercs:
W164 GL class GL450 (sold) - R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (passed on) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #3 of 5 (permalink) Old 01-30-2017, 12:23 PM Thread Starter
Quoted: 32 Post(s)
Yeah I think I'm gonna stay away from blocking the heat transfer from the block and even if I would do that it would be under the wire harness and all the sensors I don't I don't think there's point of the of doing that at all I will just wrap cooler itself and all the lines to it and I will call it good also I have splited cooling for the supercharger and I have five gal ICE tank in the trunk already so I purchased yesterday chill charger chemical liquid from DEI
post #4 of 5 (permalink) Old 01-30-2017, 12:36 PM
bayhas's Avatar
Quoted: 324 Post(s)
and you're still heatsoaking??? Holy moly!!!
are you sure your problem is just cooling? and you're not running lean mixture due to high boost and not enough fuel delivery?
Garage:
Former Mercs:
bayhas is offline
post #5 of 5 (permalink) Old 01-30-2017, 12:58 PM Thread Starter
Quoted: 32 Post(s)
Might be buddy if it comes to mixture I know for sure I ran too rich!!! my tune was done long time ago btw I have 185 mm crank pulley and stock upper with 82 mm throttle body also cm 30 SC pump with Mezier pump as well and still gets hot also have way bigger intercooler check online SL666 car is famous online at least was before LOl
