SDS tweaks - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 12-20-2015, 07:48 PM
ADRIAN126sec's Avatar
Date registered: Dec 2008
Vehicle: 99CL600,98CL600 Swiss import,R230 SL666, EURO1985 280 CE & XR600R Desert killer
Quoted: 32 Post(s)
Originally Posted by bayhas View Post
Originally Posted by ADRIAN126sec View Post
Hi there I've been trying to lower mine with my C4 but seems like I don't have that correct formula are u be able to show me how to do it ? I need do know correct numbers for the lowest safest setting without getting red display saying car is too low visit work shop I be been messing around with it a lot try to find correct numbers and never had luck and I hope that u could help
The suspension geometry is not maintained beyond -15mm, the R230 is a tire eater as is (due to high torque and staggered setup)
Going any lower than -15mm is a bad idea, you wheels and front bumper will also thank you.... as well as your pelvis, as the lower the car sits, the harsher the ride is...
All of the settings you're looking for are under the ABC module settings...
Hi bayhas I know that !!! ,but those damn Rommes has to be correct numbers for each strut with comas !!! I just need to know correct # on all 4 wheels cuz I can lower it as much as I want , but I can't memorized because I don't have correct Rommes is that make sens?
ADRIAN126sec is offline
post #12 of 20 (permalink) Old 12-21-2015, 06:58 AM Thread Starter
Date registered: Jul 2014
Vehicle: 2003 SL500
Quoted: 35 Post(s)
Post #14 on this link may help. It suggests it is possible to view the current romess settings on a different screen, and then just re-enter them.
https://www.benzworld.org/forums/w251...-enough-2.html
benz-SL500-newbie is offline
post #13 of 20 (permalink) Old 12-21-2015, 07:30 AM
kbob999's Avatar
Date registered: Aug 2013
Vehicle: 2003 SL55; 2011 E350 BTC
Quoted: 71 Post(s)
I added a file of step by step instruction for SDS tweaks to post #4 this thread. See if that helps.
kbob999 is offline
post #14 of 20 (permalink) Old 12-21-2015, 07:43 AM
Quoted: 32 Post(s)
Hi there so after u set everything up and got out of DAS u turned off ignition and then you turned back ON and your car was at the same lower height where u set it up right And it didn't go back to its own factory height ?
post #15 of 20 (permalink) Old 12-21-2015, 07:45 AM
Quoted: 32 Post(s)
Hi there for some reason that link don't work for me should I research in R251 forum How old is that link ?
post #16 of 20 (permalink) Old 12-21-2015, 10:28 AM
kbob999's Avatar
Quoted: 71 Post(s)
Not sure. These are NOT my words, but those of another using the SDS while working on a W211. May, or may not, work for the R230.
I have adjustable linkages on my car, so I never needed this adjustment via SDS.
kbob999 is offline
post #17 of 20 (permalink) Old 12-21-2015, 03:00 PM
Date registered: Oct 2009
Vehicle: 2003 SL500
Quoted: 29 Post(s)
I've attached a file I've created for all of the SDS tweaks I could find. Use at your own risk! Let us know if they don't work for you.
Awesome post Kbob999, Very handy, I tried shutting my seat belt warning off, but it didn't stick for some odd reason. 1st time I thought I did something wrong, than weeks after noticed, it didn't hold, so tried again, a few weeks later noticed it didn't stick again.
I don't take her out much and now that its getting cold here she is in storage.
cadbob is offline
post #18 of 20 (permalink) Old 12-21-2015, 07:25 PM
Quoted: 32 Post(s)
K guys thank u so much and will post some pics if it will work as of right now try to work on couple others things as well so either this week or next will do update
post #19 of 20 (permalink) Old 12-22-2015, 03:09 AM Thread Starter
Vehicle: 2003 SL500
Quoted: 35 Post(s)
ADRIAN126sec, when you find some settings that work for lowering the suspension, can you post the romess values and any other pertinent settings you used?
I just want to make sure we help the next person who attempts this by getting some known good configuration info into the record. Pay it forward.
Darren
post #20 of 20 (permalink) Old 12-22-2015, 08:18 AM
Quoted: 32 Post(s)
Darren
Will do for sure I've benn struggling with this one fore a while and I know is possible to do it MB dealer charges $400 or 600 for that and don't feel like want to pay for something that could be done by myself especially when I have my C4 !
cadbob likes this.
