Is that dipstick for my 722.9 tranny? - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 04-14-2015, 09:08 PM
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
722.9 does not have a dipstick. If there is only one dipstick tube then it is the engine oil dipstick. Many of the engines have the engine oil dipstick tube at the rear of the engine.
ERIC.
This definition tells you all you need to know about 'PC'
PC, aka, Political Correctness, is a doctrine, fostered by a delusional, illogical minority (Liberals/Socialists) and promoted by the mainstream media, which holds forth the proposition that it is possible to pick up faeces by the clean end.
eric242340 is offline
post #12 of 17 (permalink) Old 04-15-2015, 12:35 AM Thread Starter
-COBRA-'s Avatar
Date registered: May 2013
Vehicle: 2005 SL500 black
Quoted: 36 Post(s)
@bayhas , I would have taken a photo but didn't have time to go to garage today.
@Eric , true, I guess it is for engine oil.
-COBRA- is offline
post #13 of 17 (permalink) Old 04-15-2015, 06:38 AM
Gary Knox's Avatar
Date registered: Nov 2013
Vehicle: 2003 SL55 AMG, 1994 Porsche 928 GTS, 2007 Audi A8, 1990 MB 560 SEC
Quoted: 41 Post(s)
Cobra,
Since your car is an '05, I believe, it DOES have a 722.6 5 speed transmission. The tube behind the engine is for checking transmission fluid level. At least on my AMG, there is a red cap on the back part of the engine (not behind it). THAT red cap is for checking engine oil. But, of course, there is no dipstick for either that comes with the car!!! You can buy them on eBay, and for the transmission, you insert it until the end of the dipstick hits the bottom of the transmission pan. Pull it up and the marks on the end will show the level of the fluid.
Engine oil can be checked similarly, but it will be well above any of the marks. Best way is to verify via the electronics that the engine oil level is correct, THEN insert the dipstick, and after removal, make a mark on the dipstick showing the proper level - for future checking.
PS: MY error - forgot about the difference between SL55 and Sl500 regarding trannys. Bayhas has it right in a later post.
Gary--
'03 MB SL55 AMG - Sophie
'07 Audi A8 - Audrie
'97 BMW 840Ci - to be named later
'74 BMW 3.0 CSi - Lorelei
'94 Porsche 928 GTS - Recently departed to OR
'90 MB 560 SEC -Brunhilde, recently moved to Maine
Gary Knox is offline
post #14 of 17 (permalink) Old 04-15-2015, 10:53 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 324 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
There is only one way to tell for sure... PM me your vin, and I ll send you the full report of your components...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X166 GL CLass GL63 (///AMG)
Ducati 999 with Termignoni and CF
Former Mercs:
W164 GL class GL450 (sold) - R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (passed on) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #15 of 17 (permalink) Old 04-15-2015, 12:00 PM
bayhas's Avatar
Quoted: 324 Post(s)
Just confirmed via VIN that the tranny in question is indeed 722.9
-COBRA- likes this.
Garage:
Former Mercs:
bayhas is offline
post #16 of 17 (permalink) Old 04-15-2015, 12:01 PM
tonyjroy's Avatar
Date registered: Apr 2010
Vehicle: 2005 E320(RIP) 2004 SL500
Quoted: 10 Post(s)
According to what I have read, V-8 engines got the 7 speed transmission starting in 2003 including the SL500. Another way you can check really quickly is to run through the gears in Manual. If you have a 7 speed you will see a 6 before it goes to D. If you have the 5 speed you will see a 4. Simple enough.
tonyjroy is offline
post #17 of 17 (permalink) Old 04-15-2015, 12:05 PM
bayhas's Avatar
Quoted: 324 Post(s)
The year cannot be used to rule out all models, for example 722.6 was used in AMG R230 for many years after 2003, because early 722.9 couldnt take the torque, i dont think it ever did, until 2008 when they released the dual clutch 722.9+ or something like that... with revving down shifts... fancy stuff!
The best way to tell is either by VIN inquiry, or by checking the gear actuation below D as you indicated. This methode will not be accurate once the next generation 722.x is out... unless the next one has more than 7 gears
Garage:
Former Mercs:
bayhas is offline
