SL500 2003 Battery drain mystery - Page 3 - Mercedes-Benz Forum
post #21 of 40 (permalink) Old 05-14-2013, 04:05 PM
Date registered: Jan 2013
Vehicle: 2004 sl500
I AM SORRY TO SEE YOUR POST SO LATE, BUT I HAD THE SAME PROBLEM. THERE IS A LARGE POST FOR THIS PROBLEM WHERE A FELLOW OWNER CAN EXPLAIN HOW TO WATERPROOF THE LITTLE UNIT, AND IT IS BRILLIANT! 2004 SL500
Life is too short for "canned" beer....
chuter1mz is offline
post #22 of 40 (permalink) Old 05-05-2015, 10:22 AM
Date registered: Jul 2009
Vehicle: SL500 2005 Purchased 2014 (It's a Classic)
I don’t know if this will help. I owned a S500 2001 for 8 years. Everything was working fine for six months then one morning the car battery was flat. I replaced the battery with MB part. Within a week of the car standing I had a flat battery. It was unresolvable without spending more than the car’s value.
So I resigned myself to disconnecting the negative lead from the battery and reconnecting when I needed to use the car. I did this until the replacement battery needed to be replaced again around 4 years after purchase.
I replaced the battery and hey presto the drain stopped. For 2 years until I p/x the car. I removed the battery but did not install the new one until the next day.
By leaving the car without power over night seemed to resolve the drain.
Now I own a SL500 2005 and yes I have a battery drain (intermittent) because it's been getting worse over the last 6 months. I only use the car summertime I purchased I new battery yesterday thinking that the old one was tried and due for replacement. Over night flat battery. I am going to disconnect all power to the car via the two batteries over night and reconnect in the morning.
By doing this will I have to have the keys re programmed or any thing else??
I had no issues with the S500 after the re connection.
Any help Thanks in advance.
itresolve is offline
post #23 of 40 (permalink) Old 05-05-2015, 05:18 PM
Date registered: Mar 2015
Vehicle: 2004 (MY05) SL55
Quoted: 8 Post(s)
Make sure batteries are disconnected and reconnected in the correct order.
You may need to perform some "normalisation" procedures once batteries are reconnected. See attached PDF's.
File Type: pdf Battery failure 218 Mod 2-8 Normaliation of Systems (MBK) 1-22-02.pdf (113.7 KB, 974 views)
Heatwave likes this.
nosmo Sl55 is offline
post #24 of 40 (permalink) Old 05-06-2015, 12:40 PM
Thanks for the info and *.pdf. I am thinking I will reinstall the old battery (slow drain over 5-7 days) as the new battery is shutting the system down after a few hours. Or is the "wake-up" at fault because within 10 minutes everything is back up and running normally..?
post #25 of 40 (permalink) Old 09-22-2015, 09:45 AM
Date registered: Sep 2015
I was wondering if by any chance someone would know where I could find the starter located at?
Amee:} is offline
post #26 of 40 (permalink) Old 12-01-2016, 09:40 PM
Date registered: Nov 2008
Vehicle: 2004 SL500 Sport, 1997 Mercedes E420 Sport
Quoted: 8 Post(s)
Just my two bits on this old thread but still a common problem , especially with the SL's . The rear battery warning generally leads to the discovery of other issues.The Auxiliary Battery powers "ELECTRICAL CONSUMERS" - these are the heavy hitters that no starting battery could ever hope to power. The sound systems draw a lot - 400 watts original , I have an 850 watt in my SL500 now. But it is the stuff that the car constantly monitors - the pressure in the Brake and ABC system that are the really big draws. Every time you open the door on the car the large ABS/SBC pump motor goes on to charge the accumulator. The ABC tries to level itself whenever the car is disturbed. With age none of these parts hold pressure for more than a few days - so the battery has to come into play. You can spend many thousands of dollars over really minor issues with ABC equipped cars. Don't drive yourself crazy over this. It is a Mercedes - different. Plus - starting is less of a problem than ordinary cars.
If you do not drive the car regularly you have to keep a trickle charger on the rear battery. The front one seems to be immune from issues, so just care for that like you do any car.
Gotglasses is offline
post #27 of 40 (permalink) Old 12-02-2016, 06:58 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1687 Post(s)
FYI, ABC does not use the battery except to actuate the valves, which only happens when the engine is running, thus operating the pump, and the valve requires very little current compared to other consumers like heated seats, SBC, etc.
- RODNEY
My Stable:
rudeney is offline
post #28 of 40 (permalink) Old 12-02-2016, 11:38 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 324 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
I dont know if it has been mentioned before (Didn't read the entire 13 pages)
But R230 parasitic battery drain is often traced back to a bad alarm siren/controller. PN 171 820 25 26
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X166 GL CLass GL63 (///AMG)
Ducati 999 with Termignoni and CF
Former Mercs:
W164 GL class GL450 (sold) - R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (passed on) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #29 of 40 (permalink) Old 12-18-2016, 11:18 AM
ADRIAN126sec's Avatar
Date registered: Dec 2008
Vehicle: 99CL600,98CL600 Swiss import,R230 SL666, EURO1985 280 CE & XR600R Desert killer
Quoted: 32 Post(s)
Also Instrument cluster plays a big role in this case that's what I'm going thru these days LOL
ADRIAN126sec is offline
post #30 of 40 (permalink) Old 09-15-2018, 03:24 PM
Date registered: Jun 2018
Vehicle: 1998 SLK & 1992 500SL
Quoted: 5 Post(s)
I have the same problem with my 92 500sl. It just started after I did 2 things: I put new bulbs/ and bulb holders in the dome light. I also put new batteries in the remote, which had not had worked since I bought the car 4 months ago. I have been fixing little odds and ends since then. The remote worked properly for the passenger door, but does not lock the drivers door or the trunk. I drove it once about a week ago, and the next day the battery had .5 volts. I disconnected the battery and charged it, but in the process of finding the huge drain. I am now back to trying to troubleshoot the problem. I
If the culprit is the PSE pump, will the pump be running constantly?
imelemental is offline
