SLC 180 battery drain - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-08-2019, 11:26 AM Thread Starter
Date registered: Jun 2009
Vehicle: current: SLC180 12/2016 / PAST: SLK200 R170 1996
Unhappy SLC 180 battery drain
gentlemen, i will use 4chan style to don't waste our time so story time:
owner of R170, loved the car, sold it
current owner of SLC180
something drains battery
battery tested - OK
after locking car - noise coming from engine department
noise is on, then off, then on again
located that fuse nr. F32 is under 3.2A current on/off randomly
when F32 removed - noise is not present anymore and battery drain is low
F32 is 40A fuse - Engine electronics (nothing more detailed)
also when F32 is present, F28 (instrument cluster) has some unknown but high current in it
vibrations in motor area found on hose A1728301700/ZGS001
it's hose line in cooling department
so.. there's clearly some electronic part working, taking 3.2A from battery even when car is turned off, going on and off in "random" times, and it is with 99% precision something connected to cooling system
..any ideas gentlemen..? is there any electric pump in system what can go wrong? or some driving electronics?
btw one relay very close to F32 seems to be connected somehow in this issue but I have swapped the relay for identical one to be sure it is not a relay problem (relay is like 0.5cm located from F32)
thanks for any ideas (warranty problematic/not first owner so that's why I'm asking first here. I will try dealer but maybe some good ideas I will read here)
thanks in advance...
slkstyle is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R172 SLK-Class
2007 GL450 battery drain abtabor6 X164 GL-Class 4 12-02-2018 09:49 PM
battery drain on my c180 Alex berlein W203 C-Class 0 10-02-2016 07:07 AM
Intermittent Battery Drain - Very Annoying! MikeJT W140 S-Class 20 07-01-2016 09:06 AM
Battery drain - Command CANbus expert help? atmsmshr W220 S-Class 27 08-04-2012 05:48 AM
Mysterious Battery Power Drain hifeverz R129 SL-Class 6 05-11-2005 09:09 PM
