Hissing noise when I accelerate - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-22-2018, 08:04 AM Thread Starter
Date registered: Jun 2018
Hi, I recently had routine maintenance performed on my 2014 SLK250 Carbon Edition, and ever since then everytime I *release* the accelerator the car makes a hissing sound. It sounds like someone is opening a bottle of soda. If I accelerate a little, when I release the accelerator it hisses a short 'ppsss', if I accelerate quickly for example while merging onto the freeway, when I release the accelerator it makes a hissing sound which is a bit longer. The loudness of the hissing does not vary. I believe the engine is 4 cylinder Turbo.
I purchased the car used, and did not notice any such noise when I bought it, or over the past 6 months that I have been driving it. I am wondering, is the hissing sound normal? Does it have something to do with the turbo? Did my mechanic fix something that I didn't know needed fixing?
My mechanic performed the following actions:
1. changed the air filter
2. changed the oil, used good German oil
3. changed the brake pads, replaced with new Mercedes brakes pads
4. rotated the wheels
Thanks!
babypbenz is offline
post #2 of 6 (permalink) Old 06-22-2018, 03:12 PM
Date registered: Mar 2008
Vehicle: 1998 , SLK 230
Quoted: 26 Post(s)
This is the R170 forum for older SLK's. If it was my 1998 model I'd make sure the top was securely replaced on the filter airbox, and check the hoses around the airbox.
But you might get a better answer on your model's section of Benzworld.
Mike C 3039 is online now
post #3 of 6 (permalink) Old 07-18-2018, 05:13 AM
rpiotro's Avatar
Date registered: Sep 2007
Vehicle: 2012 SLK350
Quoted: 5 Post(s)
This IS the R172 forum. Where are YOU?
"Well, are you talkin' about what it is you know or just repeating what it was you heard?"
Grace Slick
"He has erected a multitude of new offices, and sent hither swarms of officers to harass our people, and eat out their substance."
From the Declaration of Independence.
rpiotro is offline
post #4 of 6 (permalink) Old 07-18-2018, 05:17 AM
rpiotro's Avatar
Quoted: 5 Post(s)
Thanks!
I would have to hear the car to make a determination. Those kinds of sounds are consistent with a turbocharged engine. Best take it back to your mechanic that did the work for a second opinion.
BTW, what is "German oil"?
Grace Slick
rpiotro is offline
post #5 of 6 (permalink) Old 07-23-2018, 04:27 AM
Date registered: Dec 2007
Vehicle: 2011 E 350 4matic
Quoted: 21 Post(s)
I'm not a mechanic but, agree, "Those kinds of sounds are consistent with a turbocharged engine." The turbocharger forces air into the engine and is driven by the exhaust. the more exhaust the faster the turbo spins the more air forced in the engine. When the oil was changed maybe something was moved or disconnected.
rpiotro likes this.
B15M is offline
post #6 of 6 (permalink) Old 02-05-2019, 05:24 AM
Date registered: Dec 2011
Vehicle: 82 380SL. Past: 75 450SL, 59 TR3A, 64 TR4, 66 250SL, 69 280SE, 75 450Sl, 79 450SEL
Quoted: 8 Post(s)
I have the same car in Arizona. The car is turbocharged. To reduce, but not entirely eliminate turbo lag, the turbo is constantly spinning (at about 80% and spins faster on acceleration). Mine hisses on acceleration. When I don’t want to enjoy the hissing sound, I turn the radio up.
rpiotro likes this.
sdichter is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R172 SLK-Class
