Passenger side headlamp too high. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-02-2014, 12:21 PM Thread Starter
Date registered: Feb 2013
Hey all. I have a 2012 SLK350 and my Comand system started going off and on. I took it to the dealer and they did a software update. Since then, it's worked perfectly but now I have a new problem. Last night was the first time I've driven it at night since then and noticed my passenger side headlamp was way too high. I adjusted it manually as far down as it would go but it's still too high. It was perfect before the update was installed. Could the update have caused this? How can I fix it? Thanks
LadyVolFan is offline
post #2 of 4 (permalink) Old 08-02-2014, 01:15 PM
Outstanding Contributor Always Remembered RIP
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 150 Post(s)
With xenon lamps you do this on STAR. maybe the adjustment rod has broken inside the lamp.
television is offline
post #3 of 4 (permalink) Old 08-03-2014, 01:01 AM
Sith Lord
elbeik's Avatar
Date registered: Sep 2009
Vehicle: 72 280SE 88 560SEC 92 E500 6.0 95 SL320 14 GLK350
Quoted: 231 Post(s)
If you have the xenon package, when you start the car at night / dark environment they lit up. You'll notice the beam moves around before it centers correctly.
If it's not, on either sides, then you could have a fault - must be corrected as television mentioned at the dealer.
elbeik is offline
post #4 of 4 (permalink) Old 08-03-2014, 07:08 AM Thread Starter
I'll call the dealer tomorrow. Thanks to both of you.
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R172 SLK-Class
