2006 SLK280 Right Turn Signal Stuck On - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-12-2019, 06:07 PM Thread Starter
Date registered: Mar 2019
My right turn signal is stuck on even when the car is off. I'm trying to figure out which fuse or relay controls this so I can remove it without killing my battery or having to completely disconnect the battery. All the manuals and diagrams I've found on the internet so far do not list a fuse or relay that controls the turn signals. I could really use some help and while I imagine there is supposed to be a search function on the forum all I see are google ad search functions that perform google searches.
Any help is appreciated.
ae_carter is offline
post #2 of 2 (permalink) Old 03-15-2019, 02:33 PM
DP
DP's Avatar
Vehicle: 190E, SLK350
Quoted: 2105 Post(s)
Disconnect the battery then connect back after an hour. See if it resets.
DP is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
Right turn signal inop with headlghts ON! Stuck on solid. Wayne Lambright W124 E,CE,D,TD Class 3 07-06-2017 07:36 PM
2006 E350 turn signal bulb replacement Bill51sdr W211 E-Class 3 10-11-2013 10:57 AM
Turn Signal Stuck smathews49 W210 E-Class 1 12-10-2010 02:31 PM
re: turn signal handle gets stuck rydinfly General Mercedes-Benz 1 08-18-2009 08:21 PM
First Maint. Req. for 97 S-500, Right Turn Signal Flashes on Left Side [?] foleydb W140 S-Class 1 01-04-2003 04:20 PM
