low coolant temp - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-27-2019, 01:00 PM Thread Starter
Date registered: Nov 2013
Vehicle: '06 SLK 350
low coolant temp
06 slk 350.Engine light came on and OBD code says coolant or thermostat problem. Fluid level OK. temp gauge only goes up to 75 C. ?? thermostat stuck open or sensor faulty?? Replace thermostat/ sensor??
rgoeltsch is offline
post #2 of 4 (permalink) Old 03-01-2019, 12:38 PM
DP
DP's Avatar
Vehicle: 190E, SLK350
Quoted: 1929 Post(s)
Measure the actual temperature of the coolant
DP is offline
post #3 of 4 (permalink) Old 03-27-2019, 01:05 PM Thread Starter
How do I do that in a sealed pressurized system?
post #4 of 4 (permalink) Old 04-14-2019, 06:54 AM
DP
DP's Avatar
You could scan the temperature with a hand held laser temp scanner agains the throat of the water pump.
https://www.amazon.com/Infrared-Ther...33104962&psc=1
DP is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models GeeS General Mercedes-Benz 45 03-23-2019 06:04 AM
Got Codes? Check this list Check Codes W210 E-Class 80 06-12-2017 09:00 PM
coolant temp warning @ 80C hauker W164 M-Class 14 07-23-2016 04:07 PM
Coolant Low Warning message NESTIAM W211 E-Class 2 03-11-2014 03:13 PM
COOLANT TEMP REGISTERS LOW? MAXIMUMBOB R/C107 SL/SLC Class 8 05-31-2013 05:08 PM
