Advice needed - Roof latch cylinder failing to latch - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-19-2018, 09:37 AM Thread Starter
Date registered: Sep 2018
Vehicle: 2005 SLK 350
Unhappy Advice needed - Roof latch cylinder failing to latch
So I went through the process of replacing the piston rod seal with a seal purchased off of eBay, following instructions that I found here. After I assembled everything, the roof would not operate correctly. I figured it need more hydraulic fluid, so following a guide here, I was able to access the pump reservoir and added the correct MB fluid until the roof was able to complete it's cycle of raising & lowering the roof/trunk components completely.
But it appears that the latch cylinder is not holding pressure - it latches the latches to lock the roof in place, but then seems to 'relax' and releases pressure so the latches back off from being completely closed.
Looking at this diagram - I don't think it is not sealing around #9 - the piston seal.
The image seems to indicate that the piston seal is almost a rubber gasket. I didn't take any pictures when mine was disassembled, but I seem to remember that this was more of a metal bushing on the piston.
Does anyone have any ideas on how to trouble shoot this - or what my next step is? Is it possible to just purchase the piston? Without the whole latch cylinder?
TIA
Craig
csantelman is offline
post #2 of 2 (permalink) Old 10-13-2018, 04:46 PM
DP
DP's Avatar
Vehicle: 190E, SLK350
Quoted: 2105 Post(s)
Can you film your setup and operation?
DP is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
