Roof rattle - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-17-2018, 07:35 AM Thread Starter
Date registered: May 2018
Vehicle: SLK 200 R171 sport edition 2007
Roof rattle
hello everyone is a new member from Italy, i 've a slk sport edition r171 2007, i read this interesting discussion:
https://www.benzworld.org/forums/r171...attle-fix.html
I want to try to lower the bracket, can you tell me on which screw to operate and also the type of screw?
Thanks for your help.
sat22 is offline
post #2 of 9 (permalink) Old 05-17-2018, 12:44 PM
Smackrattle's Avatar
Date registered: Nov 2005
Vehicle: vintage
Quoted: 980 Post(s)
Have you positively identified the source of the rattle? I would only start adjusting screws after you have exhausted all other possible origins for rattles and squeaks.
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is offline
post #3 of 9 (permalink) Old 05-17-2018, 01:10 PM Thread Starter
Hi, yes, mercedes assistance lubricated all the gaskets of both the roof and the boot; there is only a little driver side noise left behind at the top between the rear glass and the triangular glass that is felt only on the rough road.
Smackrattle likes this.
sat22 is offline
post #4 of 9 (permalink) Old 05-17-2018, 01:19 PM Thread Starter
I forgot, the noise only feels closed roof and with the glass of the door pulled all up to beat, if the glass drops a little the noise disappears.
sat22 is offline
post #5 of 9 (permalink) Old 05-18-2018, 02:49 AM
Vehicle: vintage
Quoted: 980 Post(s)
I'll have a look at mine later - but I've been very fortunate with mine. It only squeaks a bit when the seals become dirty/dry.
post #6 of 9 (permalink) Old 05-18-2018, 02:55 AM
Vehicle: vintage
Quoted: 980 Post(s)
OP says:
I lowered it two notches (note that the adjustment screw is on the back side of the bracket).
So I assume the screw is behind the notched area on the bracket, accessed from inside the car. Please note - do not kneel (put your knee) on the seat. The heating elements are very fragile and will likely break.
It's almost certainly a 'Torx' screw - most of the fastenings on the 171 are this type of star-shaped screw.
post #7 of 9 (permalink) Old 05-18-2018, 04:09 AM Thread Starter
Wink
Thanks Smackrattle for the advice, but I do not have the heated seats, I'll try.
sat22 is offline
post #8 of 9 (permalink) Old 01-08-2019, 07:50 AM Thread Starter
Hello guys, I take this post saying that the brackets you were talking about were well placed, but I found that the noise is heard only when the glass of the door goes up, just a very small movement down and the noise is no longer heard , as if the glass went too high. I ask you if I can put a very small paper-like thickness between the glass and the seal and memorize the new position of the glass stop in order to eliminate the gap. It is feasible?
sat22 is offline
post #9 of 9 (permalink) Old 01-22-2019, 03:21 PM
DP
DP's Avatar
Vehicle: 190E, SLK350
Quoted: 2105 Post(s)
Make sure that the roof closes tightly. That's the front two latches.
DP is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
