M271 engine details sought - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-16-2006, 06:40 AM Thread Starter
Hello all. I am trying to find any technical documents/info on the 1.8L kompressor engine of the SLK200k (M271). Has anybody got any links or any articles on this engine?? All I can find is details about the 6cyl engines...
Thanks
ierax is offline
post #2 of 15 (permalink) Old 07-16-2006, 10:46 AM
etyu's Avatar
Date registered: Mar 2006
Vehicle: 2008 SLK55 AMG
You may want to PM Ianx.
2008 SLK 55, Pewter, Beige Nappa leather interior
mod R170 antenna, cargo tray, OEM Lexan windschott, stainless steel trunk handle, aluminum doorlock pins
PIAA 5W Super White parking lamps
SmartTop v1.0, Kleyman 3BFM V1.5 (Noregrets Custom Works)
etyu is offline
post #3 of 15 (permalink) Old 07-16-2006, 12:45 PM
Pascal_TTH's Avatar
Date registered: Jun 2006
Vehicle: SLK 200 Kompressor
http://www.mercedes-slk.com/modules....=article&sid=8
Pascal_TTH is offline
post #4 of 15 (permalink) Old 07-16-2006, 02:25 PM Thread Starter
Thanks for the link Pascal. I did a search but could not find anything solidly technical. My french is a bit rusty but is a good start . And your pics are great!
I presume you were the one that wrote the article. Congratulations.
Do you know what is the internal combustion ratio of the engine as used in the SLK? Is the water pump a proper steel rotored one or is it one of those plastic jobs??? Do you know any details about the chargecooler core and its thermal efficiency?
etyu. Ianx seems to be on a business trip I think. I will try to PM him as you say if he has an technical documents. I know that there are at least 3 versions of the m271 engine but cannot source anythic specific and decently technical about the one on the slk .!
ierax is offline
post #5 of 15 (permalink) Old 07-16-2006, 03:53 PM
etyu's Avatar
Try DanSLK.
etyu is offline
post #6 of 15 (permalink) Old 07-16-2006, 04:07 PM
Pascal_TTH's Avatar
Really technical data, I don't have any...
But, I know the engine have different power but I'm not sure it's the same M271 :
- 90 kW without Kompressor for Classe C
- 105 kW within C Coupé
- 120 kW for SLK
- 135 kW in new Classe E
I already try to get some informations from Mercedes but I don't have any answer. Opel was much more friendly and send me all technicals data for the engin of my Coupe 2,2l 16v. Everything was written : material for each part, weight, shaft timings, etc.
I have also done a lot a search but don't find what I want. I suppose you look for it for some engine tuning ?
post #7 of 15 (permalink) Old 07-17-2006, 08:39 AM
benz--man's Avatar
Date registered: Nov 2005
Vehicle: '06 SLK350, '01ML320
From the MB website:
Engine 4 cylinder
Configuration In line
Valves 4 valves / cyl.
Displacement 1,796 liters
Compression ratio 9.5
Power (max.) 120 kW @ 5500 rpm
Torque (max.) 240 Nm @ 3000-4000 rpm
benz--man is offline
post #8 of 15 (permalink) Old 07-17-2006, 11:41 AM
Vehicle: SLK200K
Some different types of M271.
180 kompressor
Displacement 1.796
Bore 82.0
Stroke 85.0
Compression 10.0:1
Power 143hp @ 5200 rpm
Torque 162lb/ft @ 2500 rpm
200 kompressor
Displacement 1.796 liters
Bore 82.0 mm
Stroke 85.0 mm
Compression 9.5:1
Power 163hp @ 5500 rpm
Torque 240Nm @ 3000 rpm
200 CGI
Bore 82.0 mm
Stroke 85.0 mm
Compression 10.3:1
Power 170hp @ 5300 rpm
Torque 184lb/ft @ 3000 rpm
230 kompressor
Bore 82.0 mm
Stroke 85.0 mm
Compression 8.5:1
Power 192hp @ 5800 rpm
Torque 192lb/ft @ 3500 rpm
Formula 3
Displacement 1.997 liters
Bore 82.5 mm
Stroke 93.4 mm
Compression 13.0:1
Power 210hp @ 6000 rpm
Torque 265Nm @ 5000 rpm
/Bengt
bejak is offline
post #9 of 15 (permalink) Old 07-17-2006, 04:44 PM Thread Starter
Pascal_TTH. Yes I am looking into some tuning but since I live in a country that is very warm (and have experience with running turbocharged cars here) I need to make sure that the peripherals of the engine are up to the task.
The factory chargecooler will most possibly not be up to the task and will need replacement with a custom made intercooler (pro-alloy being my favourites with my experience in tuning cosworth engines ).
I am looking at the kleeman conversion, complete with header, that ups the output of the engine to about 235 hp.
Roots compressors and especially the m271 derivative used in the c-class run quite high temperatures ,so installation of proper cooling is a must.
That's why I am trying to find detailed technical manuals/data on the m271 engine used in the slk.That, and love for all things mechanical
bejak, thanks for the figures. Are there more than one derivative for the 200 kompressor engine? most probably.... The new facelifted 200 kompressor e-class has an ouput of 179 hp from its m271 engine...
Compression ratio would matter depending on the extra boost applied to the engine .
The slk has a terrific chassis and really needs some engine tuning and an LSD to become a proper sports car. Of course it has to be many things to different people, so its full potential is untapped as it initially emerges from the factory.
ierax is offline
post #10 of 15 (permalink) Old 07-18-2006, 05:42 PM
Pascal_TTH's Avatar
Hello ierax,
https://www.benzworld.org/forums/r171...rformance.html
We are looking for the same thing ! I read a lot about want I can do to the engine. Most tuner offer to change pulley with a smaller to make the eaton rotates faster and bring more air. All this engine tunings come with a sport air filter ad an ECU remap excepted Carlson. It gives about 200 hp and from 260 to 305 Nm (according to them, no dyno graphics). Second stage often tells about changing intercooler and even waterpump pulley (if I remember well). After, it's still possible to change exhaust and/or camshafts.
In Belgium, new E-Class runs with M271 engine with 184 hp and 250 Nm (from 3500 rpm to 4000 rpm). I suppose it's the same engine or nearly. 184 hp can be nice enough for me. So I try to found more about this engine to see what's the difference (only ECU ou ECU and pulley or more).
I would like first to have more torque or keep 240 Nm but 500 rpm lower. Second, it will be aos niceto keep the torque higher after 4000 rpm. 260 Nm @ 3000 rpm and about 185 hp @ 5500 rpm is my target. Not too hard for the engine.
I still haven't found a serious tuner in Belgium to do the job that I want.
PS : It's hard to find technical datas on Mercedes engines. It's easier with other brand very common like Opel, Peugeot or Renault.
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
DIY-M271 oil change...sort of BF_JC230 W203 C-Class 30 12-09-2014 08:08 AM
M271 BS Boost Kit Kentzee W203 C-Class 5 01-06-2006 08:43 AM
Any possibilty to change my M271 engine 200K for a 230K with MB parts? Corsino W203 C-Class 6 12-08-2005 11:18 AM
Interesting Engine Technical Details California SLK R171 SLK-Class 0 07-06-2004 08:53 PM
M271 C230 1.8 Liter engine supercharger pulley? breastroker W203 C-Class 1 04-24-2004 08:15 PM
