M271 engine details sought - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 07-18-2006, 06:18 PM Thread Starter
Hello pascal!
your figures on the new facelifted E-class are correct, 184 hp.mine were 5 hp short.
From what I have read and asked around (and had a talk with my mechanic that specialises in turbocharged engines ) the standard ecu will allow for more boost as per carlsson without a secondary ecu or reprogramming.
Problem is , you are bound to have pre-kcocking and other harmful effects under a constant strenuous load or in hot temperatures...
That's where the k-box used by kleeman seems attractive. Ideally, the factory ecu should be re-programmed but only mkb seems able to do that and these fellows are way overpriced and do unecessary changes to the engine.
I will explain further :..
Apart from upping the boost through a new pulley ,there are two major constraints with the m271 engine.
The first and critical one is that horrendous charge cooler. Eaton kompressor engines are generally more susceptible to high temperatures than turbocharged engines when increasing the boost, and the stock plasticky chargecooler makes it no favours in the case of the slk.
Having run various cosworth cars in various stages of tune over the years ( a quite different car than the slk but fun) I can vouch for pro alloy for making some of the best intercoolers around. They have some excellent cores and custom make whatever you want depending on the boost the car will be running etc.
In our case the chargecooler will need to be sent to them in order for them to measure and produce an intercooler that will fit in place as the original one and perhaps be a little bigger if space allows it.
The kleeman conversion I have in mind , SLK 20 K2 Performance kit + Header 235 HP / 325 Nm (you can see it at kleeman.dk ->webshop runs 0,2 more boost than stock, that is 0.8 bar.
Anyway the first critical step is taking care of the extra cooling needed, You will notice that various tuners quote a difference of +10 HP with or without a new intercooler (i.e from 195 to 205). Due to a denser mix ,etc etc...
The second item that needs attention is the headers of the m271, that are pathetic and allow for very restricted airflow.
In my experience it would be much better to go the whole step towards getting the performance kit plus headers ,rather than one step at a time.
Kleeman quoted me 235 hp with 325 NM torque (no idea at what revs) which sounds probable. There is of course the downpipe with the precatalyst to take care of ,and the exhaust system ,but that is another story.
I am trying to find whether the m271 engine in the slk has a steel head gasket or one of those horrid paper ones they used to have,that will perplex matters if more boost is applied and longevity is necessary.
But taking into account that the 1.8k engine could do 193 hp from the factory, with a mediocre chargecooler and a very restrictive header , 220-230 sound very probable and without much trouble if the necessary peripheral components are uprated.
The M271 engine runs out of puff after 5000 revs, so the conversion will give the necessary top end. You can certainly do the pulley and secondary ecu conversion first, but in my book the stock chargecooler has to go, even if you were running a stock engine...Belgium may not be as hot as Greece, but more efficient cooling makes for a better and more reliable engine every time. Chargecoolers are a sorry solution,but cheap compared to a decent intercooler.
The M111 engine in the previous slk r170 needed an uprated water pump,this does not seem to be the case in the m271 used in the slk r171. (Although it is probably a plasticky one like all german manufacturers seem to use nowadays)
Since this is getting a bit technical and some people may be averse to tuning, if you want to compare conversions and problems of tuning the engine in our slk, contact me via PM (unless we have support of our forum members ). I have been very aggressive the past three weeks trying to track down all available options and possible problems.
ierax is offline
post #12 of 15 (permalink) Old 07-19-2006, 11:51 AM
Vehicle: SLK200K
Yes the SLK has a terrific chassis and I have improved mine some more by installing the KW coilover kit. Now I could use some more power. Highest output from a tuning kit as I understand is the Kleemann stage one kit which gives 210hp / 310Nm and the stage two kit with headers and complete new exhaust 240hp / 320Nm. I think the company Vaeth also has a kit which gives 240hp. They warned me about the automatic trans in combination with so much power.
/Bengt
bejak is offline
post #13 of 15 (permalink) Old 07-19-2006, 01:24 PM
Pascal_TTH's Avatar
Date registered: Jun 2006
Vehicle: SLK 200 Kompressor
Hello ierax,
Nice to read about you. In Belgium, temperature is not an issue (except this month very very very hot). That's the reason why I don't care too much about a better intercooler. But you are right, breathing colder air is far better.
In an other car no charged, it install a carbon air box BMC. It was the same size as the original air box. With a chip tuning, the engine Opel 1,6l 16v goes from 100 hp @ 5500 rpm and 150 rpm @ 4000 rpm to 113 hp (same rpm) ant 169 Nm (also same rpm).
I look to do the same air box remplacement but there is not enough space to install a BMC carbon air box. I think it can do a nice job because now BMC made carbon air box that can fit directly on air flow sensor. This could help the air flaw going far better and bring better response when you go full throttle.
The problem here in Belgium is that it's not allowed to change any part of the engine. Only air filter and exhaust is allowed. ECU remap is not *visible* so no problem. But if it was possible to do anything :
- Carbon air box to remplace stock air box.
- Any pulley kit with ECU remap
- Better air cooler
- Better manifolders (not sure it's the right word)
- Sport cat
ECU remap must be done on a dyno with knocking sensor on the engine. ECU fine tuning bring more adavance to ignition. This leeds to more mpower but can generate knocking witch can domage the engine. All this can bring about 220 hp and +300 Nm.
I already got some informations :
http://www.vaeth.com/pages/slk/r171/slk200k.php : 2460€
http://www.brabus.com/homee.htm : 2180€
http://www.carlsson.de/en/motor/benzin/ck20ab.php : 2390€
http://www.kleemann.dk/site/Main/thecars/slkr171 : 3120€
http://www.digi-tec.de/de/leistung/detail.php?id=818 : 1800€
After all this engin tunings, the engine need SP98. I suppose it's esay to find all over europe.
I have found nice guys in Belgium near Brussels. They have a dyno and they sold also carbon air box.
PS : sorry, for poor english but really nice discussion file !
Pascal_TTH is offline
post #14 of 15 (permalink) Old 01-01-2011, 06:21 PM
drb930's Avatar
Date registered: Sep 2008
Subscribed!
Anyone know the max displacement that can be obtained from the M271?
Thanks,
Dave
drb930 is offline
post #15 of 15 (permalink) Old 05-31-2018, 09:49 PM
drb930's Avatar
Anyone know where to get a stroker crank?
drb930 is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
DIY-M271 oil change...sort of BF_JC230 W203 C-Class 30 12-09-2014 08:08 AM
M271 BS Boost Kit Kentzee W203 C-Class 5 01-06-2006 08:43 AM
Any possibilty to change my M271 engine 200K for a 230K with MB parts? Corsino W203 C-Class 6 12-08-2005 11:18 AM
Interesting Engine Technical Details California SLK R171 SLK-Class 0 07-06-2004 08:53 PM
M271 C230 1.8 Liter engine supercharger pulley? breastroker W203 C-Class 1 04-24-2004 08:15 PM
