Please recommend a charger - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-26-2017, 08:45 PM Thread Starter
Date registered: Sep 2017
Vehicle: 2014 SLK250
Hi,
We have a SLK-250 and a C-300 that both get very little driving time. Both are still under warranty and I recently had a problem where the SLK wouldn't start. Seemed like the battery was depleted and while roadside assistance actually came out and replaced the battery I'm thinking I'd like to use a charger during the winter to top off the batteries when they are idle for a couple days.
I tried a keyline smart charger and it doesn't seem happy using the jump points on the car. I need to pop the battery cover off and attach it directly to the battery to make it work.
Does anyone know of a charger that I can attach to the jump points? I'd like my wife to be able to do it also and there is no way she screwing around with a battery cover.
Thanks for any help!!!
tom-benz36 is offline
post #2 of 5 (permalink) Old 09-27-2017, 03:23 AM
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 68 Post(s)
i use a ctek mxs 5.0 to maintain a charge. very smart charger and its the OEM charger of choice for many manufactures!
comes with quick connect connector so its just set and forget. all automatic
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
post #3 of 5 (permalink) Old 09-27-2017, 08:04 PM
Date registered: Sep 2008
Vehicle: 2003 SLK230 USA model, Auto Transmission, Stock, Firemist Red
Quoted: 32 Post(s)
I have a Stanley Re-chargeit 15 amp. I got a great deal Walmart online. It has an automatic charge that fluctuates from 15 amp to lesser amp as battery charges, and shuts off until needed again. It has a battery reconditioner I have used to revamp my Mercedes battery. Also: engine start, alternator test, battery voltage, real time display featuring percent charged plus. Really next generation technology for IIRC under $50.
Thom
Automatic Transmission
No Alterations/Stock
Southeast, USA
DecoThom is offline
post #4 of 5 (permalink) Old 10-12-2017, 05:38 PM
ABTguy's Avatar
Date registered: Feb 2014
Vehicle: 2002 R170 SLK 230
Quoted: 2 Post(s)
I have a Bosch C7 charger, it can even regenerate a depleted battery.
ABTguy is offline
post #5 of 5 (permalink) Old 10-12-2017, 06:04 PM
Quoted: 32 Post(s)
Sounds good, does he have similar features to the Stanley Re-Chargeit?
Thom
Southeast, USA
DecoThom is offline
