Ignition coil booster mod! - Page 17 - Mercedes-Benz Forum
post #161 of 171 (permalink) Old 05-12-2019, 10:44 AM
Askerberg's Avatar
Date registered: Jan 2019
Vehicle: 1998 MB W202 C200 KOMPRESSOR
Quoted: 2 Post(s)
This is what I have
the picture quality is bad, but all I can say there isn't any Fuse stand for coil on that paper.
Enlarged the pictures
ID:	2512058   Click image for larger version
Askerberg is offline
post #162 of 171 (permalink) Old 05-12-2019, 07:36 PM Thread Starter
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 66 Post(s)
worse case is you intercept the power wire to the coil directly. the fuse swap just provides convenience and does the same thing, intercept the power to the coils.
will take a look at the wiring diagram in WIS to see where the power wire originates from
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
post #163 of 171 (permalink) Old 05-12-2019, 11:19 PM
Askerberg's Avatar
Quoted: 2 Post(s)
Thank you very much Subby. Appreciate your help.
post #164 of 171 (permalink) Old 05-13-2019, 02:37 AM Thread Starter
Subby_'s Avatar
Quoted: 66 Post(s)
this is below for a w202 c200.
the fuse for the ignition coils is at the k40 relay. that is inside the black box in the engine bay. within that black box the k40 relay has a bunch of fuses on the top if it.
as per WIS the fuse is "F6" 15 Amp
before doing anything check its the correct fuse. unplug it and try to start the car. it should not start as no spark. also check to see if spark occurs by unplugging one coil and plunging in a test spark plug and ground it to a metal part of the engine. as you crank (just quickly) u should see it spark.
then remove the fuse and then re-try. if no spark, then 100% thats the fuse.
plug the booster into that fuse socket!
khomer2 likes this.
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #165 of 171 (permalink) Old 05-13-2019, 06:53 AM
Askerberg's Avatar
Quoted: 2 Post(s)
post #166 of 171 (permalink) Old 05-13-2019, 11:26 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 201 Post(s)
Subby,
Out of curiosity, I was reading thru the many threads and comments of past years regarding the firestorm. I was astonished at how many readers commented negatively on this simple coil boost upgrade that would result in a potential (catastrophic) outcome. Where did all this negativity coming from?
khomer2 is offline
post #167 of 171 (permalink) Old 05-13-2019, 11:48 PM Thread Starter
Subby_'s Avatar
Quoted: 66 Post(s)
I assume it comes from politics and other agendas...
technically it works and works well. there are big name commercial units that do the same/similar thing but are $$$.
I have had mine for years now and no coils or plugs have been destroyed. In a stock car, this might help but it's more noticeable in a modified car as in most instances we are running almost double the boost pressure now.
stock psi around 6.5psi, most modified SLK's around 11-13psi now
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #168 of 171 (permalink) Old Yesterday, 12:01 PM
Askerberg's Avatar
Quoted: 2 Post(s)
I have received the booster finally. Will test it tomorrow. I just wonder will it work properly with 3 prong sparks just for checking it, for temporary untill I get the iridiums ones with 1.1 mm?
Thank you very much again for your advises and help. Hope this upgrade will give me one mor half a second)))
post #169 of 171 (permalink) Old Yesterday, 03:40 PM Thread Starter
Subby_'s Avatar
Quoted: 66 Post(s)
3 prong plugs will be fine. the advantage of 3 prongs is they last longer compared to a single prong copper plug. the disadvantage is they are not adjustable.
iridiums are very good but cost $. they will last a long time
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #170 of 171 (permalink) Old Yesterday, 04:58 PM
Date registered: Mar 2008
Vehicle: 1998 , SLK 230
Quoted: 25 Post(s)
I find 3 prongs resist fouling a lot better than conventional plugs- if you're running rich in heavy traffic.
Mike C 3039 is offline
