Just changed my brakes and I have a few questions. - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-02-2011, 10:10 AM Thread Starter
Date registered: Apr 2009
Vehicle: 2002 SLK230
I just changed my brakes (Dealership brakes) due to the brake pad indicator light coming on whenever I brake. So I decided to buy Akebono ceramic brakes to lessen the brake dust. Anyone have any opinions or experience with Akebono brakes?
The rear rotor's depth was fine. The front rotors are different. I'm not sure if the front rotors have a groove on the outer rim which makes the inside part (where the brake pads hit) about a little over 1/16" deep but not as far as 1/8". Is that normal for the front rotors? Or should I replace them?
I also decided not to bleed the brakes after replacing each pair of brake pads. Should I have bleeded the brakes? What are the advantages or disadvantages of bleeding the brakes after installing new pads?
After I have placed the brake pads, I took it for a test drive and the brake pedal feels softer than before. They also squeek when going in reverse. Would it be because they are ceramic brakes? Please give me your opinions.
Thanks.
whatda is offline
post #2 of 15 (permalink) Old 05-02-2011, 10:33 AM
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
Did you measure the rotors? I'm betting you need to ones. You always want to replace and bleed brake fluid when you replace the brakes. And repack the bearings, I haven't touched my car yet so i'm not sure if we have any. If/when you replace the rotors you need to hit them with brake cleaner before installing too
Benznoob26 is offline
post #3 of 15 (permalink) Old 05-02-2011, 02:24 PM
cacecef's Avatar
Date registered: Apr 2007
Vehicle: 98 red 230 slk
YIKES ! Replace brake fluid every 3 years regardless of brake pad use. Not every pad change! Hub bearings depend on ware, but I've got 156000k miles on mine and probably due for its first change. Rotors, unless they're warped are probably good thru these pads. No need to bleed brakes to replace pads. Might want to try some brake quiet on the pads.
cacecef is offline
post #4 of 15 (permalink) Old 05-02-2011, 04:07 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 34 Post(s)
+1 with cacecef - had Akebonos now for over a year (with new rotors) - no problems - no noise and similar to OEM in feel - AND NO DUST!
Note - they came with lube for the back of pads - did your dealer use the lube?
I think its normal for a spongy feel until the pads are fully bedded into the old grooves in the disc - also a good idea to deglaze old discs to get rid of surface 'polish'
When you get a vibration when braking at speed, you can be almost certain that your discs are close to minimum thickness and starting to warp - if you have a sixteenth inch ridge you are getting close - discs are not too expensive - ATE make a grooved disc that tells you when you at minimum - 'bout $60 Tirerack from memory?
Oberoi
oberoi is offline
post #5 of 15 (permalink) Old 05-02-2011, 05:07 PM Thread Starter
After 1 day of driving (20~ miles), I see orange streaks on the stock rotors. I've never seen that before, maybe it's from the ceramic pads? Also the brakes squeak usually for the first few applications of braking and right when I reach my destination. I did put the vibration solution where the calipers meet with the brakes.
I am planning on replacing the rotors next weekend. I am probably going with brembo rotors for the front. I can't find brembo rotors for the rear online anywhere or if brembo rotors are even sold for the rear.
I will also probably look into replacing my brake fluid. I need to find a DIY somewhere on this forum.
whatda is offline
post #6 of 15 (permalink) Old 05-07-2011, 09:56 PM
Kobus's Avatar
Vehicle: 2001 SLK 320(215K Miles), 2002 E320 Special Edition(182K Miles)
Quoted: 29 Post(s)
If you use old rotors with new pads, it will squeal until the edge has worn away the pad so that the pad conforms to the shape of the rotor. Only at that stage will your braking improve and the squealing stop. May take in excess of 1,000 miles.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #7 of 15 (permalink) Old 05-07-2011, 10:45 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
A good rule of thumb is to make sure you have all your questions answered before you start a job.
Eyeballs are useless for judging rotor wear, that's why they make micrometers and stamp the minimum thickness into the perimeter of the rotor. If you are going to reuse them any lip should be cut off (or it's likely to rub the edge of the new pads and cause harmonics and vibration) and it's a good idea to deglaze the face of the rotors with some emery cloth. Hopefully you won't have too badly misshapen the pads with the old rotors.
Good luck.
Check Codes is offline
post #8 of 15 (permalink) Old 05-08-2011, 08:56 PM
Benznoob26's Avatar
Do you have a source on the 3 years statement? I've never heard of anyone replacing fluid when it's not low...only time it gets low is when the pads are worn or from leaks... I had 6 years/76k on all my Silverado brake components which all worked fine up until 74k..brake fluid was clear.
He never mentioned what year/model he had and the mileage on it.
You need to repack bearings on all cars every 30-60k miles or they will burn up.
post #9 of 15 (permalink) Old 05-08-2011, 09:09 PM
Date registered: May 2010
Vehicle: 2007 c280 4matic
Source for 3 year interval for brake fluid changes? The maintenance book that mercedes gives you with your car says every two years-time dependent, not milage.
danl b is offline
post #10 of 15 (permalink) Old 05-08-2011, 10:29 PM
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 67 Post(s)
2 years is what WIS says. its time dependant not kms. regardless its cheap and easy to do as brake fluid absorbs mosture from the air lowering your fluids boiling point... leaving it in there too long can start corrosion on your ABS pump and other brake parts
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
Changed brakes, MERCEDES ARE GREAT!!!! 442john W126 S,SE,SEC,SEL,SD,SDL Class 6 07-18-2009 07:12 PM
Changed Rear Brakes...now BARELY ANY brake pressure!! dieselbenzfan123 W123 E,CE,D,CD,TD,TE Class 14 01-01-2009 01:08 PM
Questions after MAF changed loredan W220 S-Class 1 02-06-2007 12:58 PM
Getting my Brakes changed, had a ? LorinserAMG C208/A208 CLK-Class 2 03-19-2005 07:44 AM
If you've changed your CLK55 brakes, I want to buy your parts Scorchie C208/A208 CLK-Class 10 12-14-2001 12:22 AM
